Replacement of antenna in simulation
Enemalieo
Joined Aug 8, 2023
Trying to simulate a transmitter circuit on Proto, and I cannot find the antenna. Please What can I use to replace the antenna in the circuit?
LowQCab
Joined Nov 6, 2012
5,101
When using very high Frequencies,
it is unlikely that a "Real-World" Antenna can be accurately simulated.
What Frequency-Range are You using ?
What type of Antenna are You using ?
Enemalieo
Joined Aug 8, 2023
The simulation is that of a simple transmitter circuit.
Alec_t
Joined Sep 17, 2013
15,126
What is the output impedance of the transmitter driving the antenna? Perhaps just a 50 Ohm (or whatever) resistor would suffice as the antenna model.
