TSOP 1230 IR receiver module replacement
DragonNLC
Joined Apr 29, 2024
24
Hi there, what is the best recommended replacement for obsolete TSOP1230 IR receiver module for remote control operation? Thanks
28,614
What part of the IR remote receiver has failed?? Unless it is the IR sensing diode, the rest of the receivers that I have looked into is just an amplifier with good high frequency response, up to possibly 50 KHz.
DragonNLC
Joined Apr 29, 2024
24
It is being used to register scores in the display whenever the blaster/gun hits the target. At the moment it is failing to register any score(s) whenever the target was hit
ronsimpson
Joined Oct 7, 2019
4,901
Look at IR receivers and transmitters. The carrier frequency is mostly in the 30 kHz to 56 kHz range. 38khz is common. You should transmit on the same frequency as the receiver was designed for. Some of the data sheets call out what transmitter is best. Look at what "color" of light they are best at and match that to the transmitter.
DigiKey.com IR receivers Here is a link that will show many different types.
Here is part of a data sheet. This one works at 38khz. If you are off by 10% receiver is 1/2 as sensitive. At 30% off it about 1/5 as sensitive.
From the same data sheet, is shows 950 nm light is best.
DragonNLC
Joined Apr 29, 2024
24
Thank you so much for the info
28,614
Ok, so the recweiver is for a shooting gallery sort of game. So you will need to verify the frequency, probably. BUT if you can grab a receiver from a scrapped TV, give it a try anyway.
