replace relay with Mosfet transistor
Alec_t
Joined Sep 17, 2013
15,131
I haven't checked, but you may find a triac cheaper and easier to source than a high-voltage rated FET. Use an opto-triac (MOC3020 or similar) to trigger a power triac. Then you can use DC (either polarity) to drive the opto's LED.
Alec_t
Joined Sep 17, 2013
15,131
That won't be beefy enough for a 20A load. It's only rated for 4A.
Do a parametric search on your preferred electronic component vendors' sites.
mah
Joined Mar 15, 2010
393
what is the difference between Maximum Gate Trigger Current and Surge Current Rating ? how to know current gate that will hold?
also what is the difference between "Triac logic level" and Sensitive Gate Triac" ? which of them suits my app.?
i attached the circuit , i want your comments. i postulated that the load resistance is 50 ohm
Alec_t
Joined Sep 17, 2013
15,131
Maximum Gate Trigger Current seems to denote two things, depending on which datasheet is used. If listed under Maximum Ratings, it means the highest current you can pass through the gate without damaging the triac. If listed under Electrical Characteristics it means the highest current needed to guarantee the triac will trigger.
Surge Current Rating means the maximum current allowed briefly, under certain specified conditions, e.g. one full cycle at 60Hz.
A sensitive gate type would be preferred in your application, IMO.
BTW, R3 needs to be increased to avoid frying the opto-LED. 400 Ohms wold allow ~50mA to flow!
mah
Joined Mar 15, 2010
393
how did you calculate the 50 mA current ?
what do you mean surge current is the maximum current allowed ? the maximum current for this triac http://sa.rsdelivers.com/product/on-semiconductor/bta25-600cw3g/triac-bta25-600cw3g-600v-25a-gate-trigger-13v-35ma-to-220-3-pin/8009737.aspx
is 25A however surge current is 250A
Alec_t
Joined Sep 17, 2013
15,131
Voltage across R3 = 24 - 1.2 (bridge rectifier drop) - 1.5 (opto-diode Vf) - 2 (green LED) = 19.3V. 19.3V/400 Ohms = 0.048A = ~50mA.
As the datasheet says, "Peak Non-Repetitive Surge Current (One Full Cycle Sine Wave, 60 Hz,TC = 25°C) 250A".
In other words, you are allowed to pass 250A (e.g. at start-up when charging a fat capacitor), but only for one cycle of a 60Hz mains supply. For continuous use the maximum safe current is 25A (which would probably require use of a massive heatsink). It is not good practice to run any electronic component at or close to its maximum rating.
mah
Joined Mar 15, 2010
393
what is the maximum input voltage on the optoisolator ? should it be the forward voltage that is 1.4v in datasheet?
if i want to use triac without heat sink at 20A should i increase maximum rating current to 40 A? will that be ok.?
Alec_t
Joined Sep 17, 2013
15,131
It's not so much the input voltage as the current through the opto-diode that matters and must be kept below the rated maximum (which I haven't checked). LEDs need to be current-driven, not voltage-driven. Often only a few mA are needed for an opto. What the datasheet is telling you is that at the rated current the diode forward voltage will be no more than 1.4V (I just guessed 1.5V in post #28).
If i want to use triac without heat sink at 20A should i increase maximum rating current to 40 A? will that be ok.?
I very much doubt it. If we assume, for argument's sake, the triac (whatever type) drops 1V when 'on', then at 20A it will have to dissipate 20W. It will get very hot!! Use a heatsink.
Alec_t
Joined Sep 17, 2013
15,131
I thought you said your load would be 50 Ohms? That would draw < 5A. Where did you get the 20A figure?
If it really will be 20A then perhaps a FET as you originally proposed would be better than a triac from a power dissipation viewpoint. Perhaps something like this? But an SSR would likely be a better solution.
tcmtech
Joined Nov 4, 2013
2,867
Re read the thread from the beginning. You will quickly find nothing he has said or asked for adds up. :confused:
mah
Joined Mar 15, 2010
393
i don't want big size PCB , so i will prefer the Mosfet . what do you think about the first circuit in post 1?will it work fine?
tcmtech
Joined Nov 4, 2013
2,867
Re read posts 2 - 32. All of this has been well explained plus alternate functional concepts have been give as well. :rolleyes:
ebeowulf17
Joined Aug 12, 2014
3,307
Shouldn't everything on the high voltage side of the opto-isolator be high voltage? I'm assuming the mystery 24v feeding through the opto and into the gate is probably the same 24v used to power the microcontroller and therefore also the the low voltage side of opto. If this is true, it would make the opto redundant and useless because component failure could easily connect high voltage through the 24v line to the microcontroller, creating a very unsafe situation.
Please correct me if I'm wrong. Haven't actually used optos myself yet but I have some projects in mind and I want to make sure I'm understanding their application correctly. Thanks!
(When the time comes, I'll definitely post what I'm considering on these forums before trying anything involving high voltage risks. Safety first!)
mah
Joined Mar 15, 2010
393
recommend Mosfet please that don't need heatsink.
Alec_t
Joined Sep 17, 2013
15,131
We still don't know whether you are trying to switch 20A or <5A :confused:
Did you check the FET in my post #31 link? That has a rated Rds(on) of 78 milliOhms, so at 5A and 20A would dissipate ~0.4W and 1.6W respectively [Edit: see post #39 for correction]. Even 0.4W would probably require a small heatsink.
I suggest you do a parametric search of FET vendor sites for a lower Rds(on) type, but with a Vds rating > 500V.
mah
Joined Mar 15, 2010
393
i am trying to switch 20A . i will search of fet but i need your practical recommendations for the architecture of the circuit.
i think that you mean the dissipated power in 20A will = 20x20x0.078=31.2 watt
Alec_t
Joined Sep 17, 2013
15,131
Quite right. My bad. So a LARGE heatsink would be needed. Good luck finding a 500V FET with a lower Rds(on).
tcmtech
Joined Nov 4, 2013
2,867
Don't forget the bridge rectifier devices also running at 20 amps with a combined forward drop of at least 1.4 volts adding another 28+ watts of heat to get rid of. :rolleyes:
