Removing Jumper From PCB
AlbertHall
Joined Jun 4, 2014
12,653
My first thought was that maybe it is soldered into the board. After a longer look and seeing the other jumper looped through the first and looking at how the two are wired I believe they for changing between 115V and 230V input voltages to a transformer. That being the case it wouldn't make sense for it to need unsoldering.
All I can suggest is to spray some penetrating lubricant down where each wire goes. Give a while to its job then see if you can wiggle it free.
DickCappels
Joined Aug 21, 2008
10,661
Do you need to replace it sometime in the future? If not, you can just cut all of the wires at the top of their loops, otherwise I refer you back to Albert Hall in post #2
drjohsmith
Joined Dec 13, 2021
1,658
they look like the power connectors used on older disc drives in pcs
can be a pain to pull apart , but it should just "pull up" and split apart . just don't pull the wires , and a pair of pliers might be needed with a gentle wiggle ..
but streight up, if you pull at too much h of an angl , the pcb sicket will be ripped out !
yep I hate them,,,
dl324
Joined Mar 30, 2015
18,476
it seems hard to pull it, so wondering if there are any latch/locking involved.
If there are no locking tabs on the plug that isn't plugged in, it's just friction fit. It looks like there's room for a small flat blade screwdriver on the right side to start prying it out. Otherwise, use pliers to rock it back and forth. Or use the unconnected plug and its wire loop to pull out the other plug.
Tonyr1084
Joined Sep 24, 2015
9,744
I see no catches or releases that need to be depressed. Chances are good that the plug body is not truly a plug body but rather a wired header that is soldered into the PCB. Pulling it out forcefully may result in damaging the through holes and any surface traces.
It's been my experience with through hole components such as a resistor or other leaded devices that it can take up to 114 pounds of force to break a well made solder joint. More often than not the leads break long before the joint fails.
If there's reason for removing the connections, please elaborate. If they're interfacing between two boards, what do each board do? What happens if you just cut the wires? Of course that would be a semi-permanent solution, one that would be difficult to go back and fix.
panic mode
Joined Oct 10, 2011
5,295
besides... the other plug is tethered to one that is in the socket. you can look at the 'business part' of it and see what it looks like.
