Still solving the SPI issue!
If I run the PCB live, with 2x on screen terminals. one showing the SLAVE 4431 GPS DATA buffer, and the other showing all of the peripherals on the MASTER 46K20, including the GPS buffer after SPI from the SLAVE. The MASTER shows gobbledegook GPS, until the Pickit3 programmer which is attached to the SLAVE is checked or WRITE etc, then it may keep showing on the MASTER but usually only once?
C
C
