How Can AI Improve Quality Control in Modern Manufacturing?
davidmickel35
Joined Feb 12, 2026
Artificial intelligence is becoming increasingly useful in modern manufacturing. From automated inspections to production monitoring, AI-based systems can help manufacturers identify defects, improve consistency and reduce production errors.
In precision engineering, maintaining accurate dimensions and consistent product quality is essential. Machine learning can analyse inspection data, identify patterns and help predict potential production issues before they become serious problems.
I'm interested in hearing how others see AI being used in manufacturing.
  • Can machine learning improve dimensional inspection accuracy?
  • How useful is AI for detecting defects in metal components?
  • Can smaller manufacturing businesses benefit from AI-based quality control systems?
What applications of AI do you think will have the biggest impact on manufacturing in the coming years?
We don't all agree on what "AI" means. It has been a long time getting here.
I can't remember when, but I took one of the first 80286 computers available and a camera. We took a picture of a good PCB on the assembly line and stored it in memory. Then every PCB that came down the line was looked at by the camera. The math; subtracted the real-time picture from the reference picture. If the PCB was made right the picture was blank. If a wrong part was on the board, (or a missing part) you say only that part. This worked well but had some problems so we changed how the reference picture was made. The reference picture was the average of the last 100 boards. So, the computer was learning what a good board looks like.
I worked for a while where we were inspecting glass jars coming off the line. The first thing is that none of the jars met the drawings. This company had made jars for 100+ years and none were right. It was impossible to make jars that good, accurate. We had to teach the (computer + camera) what a good jar looked like and what a bad jar looked like. It was hard because every jar had defects, but certain combinations of defects were bad. For a short while the humans and computers worked together until the computers understood what to reject.
Our biggest success, involved looking at everything we could measure on a product and recording the numbers. Here is a example, everything is slight differences. If a nut is 10% too big and the bolt with it is 10% too big there is no problem. But if the nut is 10% too small and the bold it 10% too bit there is a problem. Many of the problems are seen on the assembly line but not all. We looked at the serial number for every in-warranty failure and every bad-returned product. The computer looked at all the numbers for the product that failed, even years later. Then the assembly line computers got this new data. (learned) We could reliably say that a certain new product had a 50% chance of failing within a year. That one unit would be sent to repair with a ticket telling what was wrong. We also learned what many "slight defects" did not cause the product to fail and should not be repaired on the line. Two different things were learned which greatly reduced the cost.
35,324
@davidmickel35 Do not confuse automation with AI, artificial intelligence.
CAD (computer aided design), CAM (computer aided manufacturing), CNC (computer numerical control), robotics, automated voice and vision systems, etc., have been around for a long time before AI.
Many manufacturing processes have been automated without the use of AI.
AI
(plural noun)
  1. the application of computer systems able to perform tasks or produce output normally requiring human intelligence, especially by applying machine learning techniques to large collections of data; artificial intelligence:
What is a large data base learning programs?
panic mode
Joined Oct 10, 2011
5,488
as MrChips stated automation exists for quite some time. at the moment AI based products that are some type of sensor (vision/barcode scanner etc.) are beginning to compete with traditional ones. over time AI based products will likely move in increasingly more but it is not like they are going to replace everything in one swift move. there is going to be a long period of coexistence and traditional products will likely not go away completely - there are always special cases where determinism or simplicity wins.
. I believe that AI will be only one of a loooooong list of fads, which promised would miraculously and simultaneously improve quality, shorten delivery times and reduce costs.
But as long as companies place quarterly stock value above anything else, which all publicly traded companies do, this new fad will also fail to deliver those lofty promises.
Call me a pessimist, but I would love to be proven wrong.
I spent 48 of my almost 50 years of my professional life directly involved in electronics manufacturing. I believe that AI will be only one of a loooooong list of fads, which promised would miraculously and simultaneously improve quality, shorten delivery times and reduce costs.
And I'm thinking that's where AI will thrive, in analyzing where are the returns.
