Hi J,Do you get the 1-2ms pulses from all pins rb0, rb1, rb2, if servos are disconnected?
Working
So, yes I get 3x 1-2mS from all PINs Rb0-2.
I was using smaller SERVOS for my tests and on closer inspection find that they are DIGITAL
I have the SERVOS +- volts connected to the power input (Battery) so lots of current, and the signal from the 3.3V PORTB.
I make Tricopters which have 3x motors and one SERVO for rudder. The SERVOs and motors all work with SERVO inputs, as we have been doing.
Thanks for your help, I can probably add more SERVOs myself, then include E,s get_mess section, then hopefully he will add his #137 CODE.
Here are 2x graphs for Digital and analog
C.
