Remote control by location (PIC in Oshonsoft)
sagor
Joined Mar 10, 2019
1,053
Adding a crystal, you have to change the bits of course, to enable external oscillator crystal instead of internal oscillator. You also need the small capacitors on each leg to ground, around 22pF to 27pF in most cases. Make sure the frequency declaration in the code matches the crystal frequency.
camerart
Joined Feb 25, 2013
3,847
Hi S,
I wasn't happy with the XTL sitting on top of the PIC, in case it affected the running. Was this unfounded?
Having reclaimed the components from a previous PCB, I cut out the Crystal/cap section from the old board and stuck it on PCB5 (Laest) After a few glitches, and changing the program setings to suit Crystal, it now works and the first test was promising.
________________________________________________________
$COMPDEG 301.42W
$COMPDEG 301.42W
$COMPDEG 301.44W
$COMPDEG 301.43W
$COMPDEG 297.17W
$COMPDEG 27.94W
$COMPDEG 30.51W
$COMPDEG 16.15W
$COMPDEG 331.54W
$COMPDEG 314.72W
$COMPDEG 18.32W
$COMPDEG 40.97W
_____________________________________________________________________________
Anyone following, will see this is incorrect, as it should look like e,g, $COMPDEG 001 W
I'll change this hopefully.
Thanks all.
C
camerart
Joined Feb 25, 2013
3,847
Update of the Serial input from 4431 COMP.
$COMPDEG,324,W
$COMPDEG,348,W
$COMPDEG,322,W
$COMPDEG,013,W
$COMPDEG,032,W
$COMPDEG,031,W
$COMPDEG,025,W
$COMPDEG,007,W
$COMPDEG,353,W
$COMPDEG,350,W
Much better, perhaps fixed.
C
camerart
Joined Feb 25, 2013
3,847
I'm going through the whole system as a refresher, as I get mixed up with all of the programs/PCBs.
BASE:
Since moving the Compass to the 4431 PIC, I've noticed that the BASE will get QEIDEG and the COMPDEG via the serial connection between the 2x PICs.
The 4620 will select the 4431 with MUX, and both QEIDEG and COMPDEG will be inputted.
Can I assume that the PARSE process wil separate them and work ok?
C.
camerart
Joined Feb 25, 2013
3,847
I don't see why not. The parsing scheme is designed to be flexible and work with any string values.
Hi JT,
Ah, good. I thought so, but thanks for the affirmation.
EDIT: In case there is an issue such as timing, there is another track between the PICs, that could be used as a switch.
C.
camerart
Joined Feb 25, 2013
3,847
I thought I'd post notes on each of the 4x programs, to help me remember. I'll update here.
____________________________________________________________________________________________________
PROGRAM DIFFERENCES
BASE:
18LF4620: BORI>REMOTE-BIRO<REMOTE-JOYSTICKS-QEIDEG<4431-COMPDEG<4431.
18F4431: QEIDEG from Inc enc>4620. SPI COMPDEG>4620
REMOTE:
18LF4620: BORI<BASE-BIRO>BASE-COMPDEG>4620-MOTOR/SERVO DRIVE .
18F4431: SPI COMPDEG>4620.
C.
camerart
Joined Feb 25, 2013
3,847
UPDATE:
With the compass now on the 4431 along with the QEIDEG incremental encoder.
All 6x inputs are working, for the first time :) :)
I can see lots of corrections, maybe in timing or settings, so still plodding on.
Cheers, C.
camerart
Joined Feb 25, 2013
3,847
At last here is the latest PCB (7) So from now all files should have PCB7 in the title.
If anyone would like to check them before etching, I would be grateful.
C
sagor
Joined Mar 10, 2019
1,053
Your 3.3V regulators needed that heat spreader pad underneath them for heat dissipation. However, the tab that is soldered to the pad is the output voltage, and must be isolated from the rest of the circuits. I don't see separated heat spreaders under the NCP1117 regulators. It looks like it is all one copper pour.
camerart
Joined Feb 25, 2013
3,847
Hi S,
I forgot :) I'll add them (3x) I intend to add vertical heatsinks as necessary, thanks.
C.
camerart
Joined Feb 25, 2013
3,847
Hi S,
#810 updated with amended PCB7, thanks.
C
camerart
Joined Feb 25, 2013
3,847
Does anyone think that the route of the 3.3V to the Pickit3 under the PIC and along a narrow signal track could cause a problem?
C
trebla
Joined Jun 29, 2019
599
If you power only MCU from PICkit3 then there is no problems because MCU doesn't draw much power. If there is no other big loads to drive then it should work ok.
camerart
Joined Feb 25, 2013
3,847
Hi T,
Thanks, but I meant the other way around. The 3.3REG is powering the PIC also Pickit3 as required, I wondered if the narrowing of the track could be a problem.
C.
