Regarding MOSFET
sgr
Joined Jun 27, 2017
34
If we increase the switching frequency of MOSFET 10 times then what are the parameters to be consider or verify for the MOSFET Selection and Why ?
Irving
Joined Jan 30, 2016
5,195
If you don't have enough gate drive (peak current), or its too slow in transition, then MOSFET will potentially overheat. A lower gate charge and/or lower Vgs(th) (gate-source threshold voltage) will help mitigate that, but changes to gate drive might also be needed. Channel resistance Rds(on) is less of an issue at higher speeds as the switching losses tend to dominate.
Ya’akov
Joined Jan 27, 2019
10,353
Schoolwork must be posted in the Homework Help forum because the AAC rules limit the types of information that can be provided to students doing schoolwork.
