MisterBill2
- Joined Jan 23, 2018
- 28,517
Is it possible that there is an error in the frequency calibration, and that the noise is actually 60 hZ??
AND, while that accelerometer can only use the 3.3 volt supply, if the amplifier can be powered separately than it can use a much more sensible higher voltage.
One likely noise source is any nearby lighting. Florescent tubes can radiate a huge electrostatic noise field, as can CRT displays. Not sure about other types of display, but they all are suspect radiation sources. So moving away is the simple reduction trick.
