Questions about transformer
leo0001
Joined Sep 30, 2018
79
I have a question about this transformer. How the number of primary turn and the secondary turn cannot be an integer ? Also, Isat is the current at which the transformer begins to saturate ?
Thank you and have a nice day :D
Léo
AlbertHall
Joined Jun 4, 2014
12,652
The table doesn't show the actual number of turns, just the ratio of the number of turns.
Thus the ratios 9.33 : 1 : 1.17 could mean that the number of turns is 933 : 100 : 117.
Yes, Isat is the current where core saturation can be expected.
leo0001
Joined Sep 30, 2018
79
Thank you for your reply ! I have an other question why Vi is given between an interval (141-318) and Vo or Vaux is given as a fixed value ? I mean if Vi is changing, Vo or Vaux should change too.
Thank you,
Léo
BR-549
Joined Sep 22, 2013
4,928
Dividing an integer(number of turns) by another integer(number of turns) does not guarantee an integer result.
However......a turn........is an integer.
35,101
Thank you,
Léo
It depends on the design of the transformer. There is such a thing as a constant voltage transformer that puts out a fixed amplitude AC voltage even though the input varies.
