I don't think you will have any problem using the FZT705. Its switching speed is up to the task. The only penalty that you will pay for the use of a darlington device in place of a non-darlington device is the Vce saturation voltage for the darlington device is just under a volt for the small amount of collector current that the device will be switching. Your output will swing between +4V and 0V which should be adequate for the CMOS input you are driving. Vce saturation for the non-darlington device is more like 0.2V which would give you a output high level very close to the +5V power rail.
Just something to keep in mind as you go forward with you project.
Good Luck,
hgmjr
Good Luck,
hgmjr
