Direction of induced emf and current in Generator
Status
Not open for further replies.
70Miles
Joined Dec 28, 2025
28
Hi again,
I was browsing for detailed info about induced emf and induced current in generators while found this interesting article :
I've found this page , with very good clear explanation :
https://www.cmm.gov.mo/eng/exhibition/secondfloor/moreinfo/2_4_1_ACGenerator.html
Except for one thing ,
the direction of induced currents on the image below :
What about the direction of induced current?
Should we follow the right hand rule in determining direction of induced current?
Going Back to initial image :
Lets consider the "dark (grey)" conductor of the half-loop that is rotating inside the magnetic field
From 0 degree to 180 degree : "the grey" conductor is going in downward direction.
--->>>> If we follow right hand rule the direction of induced current should be exactly opposite to the direction, shown on the picture.
Found similar issues in many other sites.
Which is correct ?
Thank you.
35,296
You can use the right-hand corkscrew rule or the Right-Hand Rule to find:
  1. the direction of the magnetic field from a current in a straight wire
  1. the direction of the magnetic field in a solenoid
  1. the direction of the force on a current-carrying wire in a magnetic field
For an electric generator, you need to observe Lenz's Law:
The direction of the electric current induced in a conductor by a changing magnetic field is such that the magnetic field
created by the induced current opposes changes in the initial magnetic field.
This follows from the law of conservation of energy, otherwise you would create perpetual motion (i.e. over unity).
In other words, use the Right-Hand Rule to find the force on the current-carrying wire. The force must oppose the motion of the generator, otherwise the generator would speed up.
My advise is, don't use the Left-Hand Rule because you will not remember when it applies. Use Lenz's Law instead.
35,296
Here is a quiz to see if you have gotten it right.
Imagine a cylindrical magnet falling inside a copper pipe.
In what direction is the induced eddy current?
Use the Right-Hand Rule and Lenz's Law to arrive at the answer.
This is an actual experiment used in a physics course on Electricity & Magnetism to demonstrate Lenz's Law.
35,296
Looking at the 90° position, apply the Right-Hand Rule.
The direction of the force on the wire pushes against the direction of motion.
Hence this is correct.
70Miles
Joined Dec 28, 2025
28
I don’t see a problem with the picture.
According to the attached picture, the direction of current should be opposite.
The Grey conductor.
Is going downwards direction
In the initial image
according RHR in the last picture the direction of current is not correct.
35,296
Go with the cross product of I x B.
The force F = I x B.
It appears that you are correct. The current direction is wrong.
I will review this later.
70Miles
Joined Dec 28, 2025
28
The Grey conductor.
Correct current direction I guess
Please follow movements of grey conductor in the initial image
From 0 to 180 degrees.
In the last post the current directions are different
In both pictures the conductor is going downwards direction
35,296
One possible cause of confusion is whether the educational site is using conventional current flow or electron flow, though I have not encountered this.
Another confusion is the memory aid for how you label the digits on the hand. Some use the index finger to represent current direction. Then there is one rule for motors and the opposite for generators.
So, which one do we use?
In order to avoid confusion, use the right-hand corkscrew rule for the cross product.
The Lorentz Force is given by the cross product of positive charge flow times the magnetic field.
F = qv X B
This will determine the direction of the force for a motor.
Apply Lenz's law for a generator.
35,296
The two drawings disagree with the direction of the current.
One of them is correct. Can you determine which one is correct?
70Miles
Joined Dec 28, 2025
28
Personally I think the initial image is wrong.
See Fleming Rhr for generator
See Fleming Lhr for motor
In Google.
Not confirmed 100 percent
35,296
In Google.
The problem as I see it is, “which rule do you remember for a generator and which rule for a motor? ”
35,296
I guess is correct.
Other opinions are very welcomed.
What I am asking, will you remember that rule?
Stick with the right hand rule for the Lorentz Force for force on a wire and use Lenz's Law for induced current.
70Miles
Joined Dec 28, 2025
28
Which one is correct?
This
or
This
Upper picture : Left conductor in downward direction
Down picture : Grey conductor is going downwards from 0 to 180 degrees
Which rule should I use ?
Thank you.
Maybe in post 19 I'll get a brief clear answer.
19 posts of questions to get a verified answer.
70Miles
Joined Dec 28, 2025
28
Hi again,
Which is correct ?
Thank you.
Again. Is it correct or not ?
Thank you
Status
