Old guy needs help for a simple project = LED to show motor run direction
cazksboy
Joined Nov 9, 2009
63
I used to dabble in electronics in high school, but now I'm old and I don't trust my memory or my judgement for even a simple project.
So that's why I'm here asking for help.
This might be a little long-winded so here's what I need help with; how do I hook up a Radio Shack "bicolor LED" to the motor control I built, so that when I switch the motor to run forward the LED glows green, and when the motor runs backward it glows red? Packaging specs for the LED to follow.
In 2012 I built a DC motor with a built-in rectifier that allows it to run on 115VAC from the wall. I wanted to equip the motor to run in both forward and reverse directions, depending on which way a DPDT switch is thrown. To accomplish that, I extracted the rectifier (a Taitron TB66) from the motor's end cap and stuck it in a project box along with the DPDT switch, AC hookup, and fuse. All components were purchased in 2012, including the LED. Motor with integral rectifier was purchased from Surplus Center. It's been working great ever since.
But as I said, I'd like to add the LED to the project box not because I need it, but just because it would look cool.
PICTURES:
HOW IT LOOKS FOR THE PAST 14 YEARS (IT DRIVES MY WATCHMAKER'S LATHE):
THE BOTTOM PIC IS THE DIAGRAM I USED TO WIRE IT UP:
View attachment 361918View attachment 361920View attachment 361921View attachment 361922View attachment 361918View attachment 361920View attachment 361921View attachment 361922View attachment 361922
cazksboy
Joined Nov 9, 2009
63
Sorry, I don't know why my pics posted twice. I tried to correct it but no luck.
Also I don't know if I posted enough info re: the LED and the rectifier. I have the specs here, let me know what else I need to post.
dl324
Joined Mar 30, 2015
18,490
No LED specs provided, so don't know if this is compatible:
The working voltage of any 1/4W 1W resistor should be sufficient.
BTW, the voltages involved are lethal.
EDIT: note that the resistor needs to be at least 1W.
cazksboy
Joined Nov 9, 2009
63
Thanks guys, much appreciated.
I went through the comments and appended dl324's circuit diagram:
LED Wiring Diagram for Lathe Motor_edited.jpgTwo questions:
1. For R1, does it make any difference which value I install?
2. It looks like the two leads powering the LED bridge the switch, which is a DPDT. Of the 6 terminals on the back of my DPDT switch, which two should the circuit be connected to? Please forgive my lack of grasp of fundamentals. I can follow directions without understanding why - I'd rather understand the reasoning, but for now I just need somebody to say "just solder THIS lead to THIS terminal, and then solder THAT lead to THAT terminal".
Thanks again....
