Direction of induced emf and current in Generator
Status
Not open for further replies.
35,183
Here is the problem.
There are errors on the internet. People make mistakes. Even I made a mistake.
So you find two answers that do not agree. How is anyone supposed to know which answer is the correct one?
Instead of following two rules that give opposite answers, sometimes you need to work it through from first principles.
35,183
Go back to first principles.
Find the direction of the force on a current carrying wire.
The only rule we use is the right-hand corkscrew rule.
The wire carrying a positive charge is pointing into the plane of the screen. The positive current flow is into the screen.
The direction of the magnetic field produced by the current flowing into the plane of the screen is in the clockwise direction.
The net magnetic field is stronger above the wire and less strong below the wire. The force on the wire is in the downward direction.
This agrees with the Lorentz Force equation.
70Miles
Joined Dec 28, 2025
28
Again:
This is correct right :
MrChips said:
Go with the cross product of I x B.
The force F = I x B.
It appears that you are correct. The current direction is wrong.
I will review this later.
This is answer, right ?
In post 24
70Miles
Joined Dec 28, 2025
28
Yep. Its ok.
I guess the existence of this site is one of the errors/mistakes that people make.
Status
