You also will need inductor DO3314-332MLBYes it certainly looks like it, Danko. I will order some and play with it.
Take free samples (up to 10 pc) here.
In addition buy ceramic capacitor 4.7uF and pot 1MΩ.
Yep did that, thankyou. Ordered ten inductors and 25 ICsYou also will need inductor DO3314-332MLB
I've printed out and bound the 14 chapters of Mike Silva's tutorials. Will use them as lessons and a reference.I ran across this series of tutorials by Mike Silva which may help a bit; it seems well-written, covers a lot of ground, and it starts at the very beginning.
@Mellisa_K, what is package of ICs you ordered, S8 or DD?Ordered ten inductors and 25 ICs
thankyou very thoughtful. i have bought those just now. I cant do smd soldering but i guess i will learn!!Good. Depends on your soldering skills and equipment possibilities,
you may need adapters so8 to dip:
https://www.ebay.com.au/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=adapter+so8+to+dip&_sacat=0
thanks for looking after me Dankothankyou very thoughtful. i have bought those just now. I cant do smd soldering but i guess i will learn!!
Let us know when they arrive. I can teach you a technique or two on how to solder those chips.thankyou very thoughtful. i have bought those just now. I cant do smd soldering but i guess i will learn!!
Thankyou cmatinez. Should I get any equipment in anticipation? A soldering oven?Let us know when they arrive. I can teach you a technique or two on how to solder those chips.
Not necessary. But what you do need is a good soldering iron/workstation. At the very least of the type that allows temperature control. Also, get yourself a good set of tweezers.Thankyou cmatinez. Should I get any equipment in anticipation? A soldering oven?
well its ok I have got this thing which enables me to see well enough I think. with good light. for example i can see the colour codes of the small legged resistorsNot necessary. But what you do need is a good soldering iron/workstation. At the very least of the type that allows temperature control. Also, get yourself a good set of tweezers.
How's your eyesight?
ive got this soldering iron http://www.goot.jp/en/handakote/rx-711as/Not necessary. But what you do need is a good soldering iron/workstation. At the very least of the type that allows temperature control. Also, get yourself a good set of tweezers.
the think about this soldering iron is that i cant get a wedge shaped tip for it. i am disappointed in that since i paid a lot for it some three years ago. maybe i should get one i can better solder smd with?Not necessary. But what you do need is a good soldering iron/workstation. At the very least of the type that allows temperature control. Also, get yourself a good set of tweezers.
re the vision thing, (LOL) would you recommend a in built model with a LED in it?Not necessary. But what you do need is a good soldering iron/workstation. At the very least of the type that allows temperature control. Also, get yourself a good set of tweezers.
my tweezers are shit. whats the go there? recommendation if you please?Not necessary. But what you do need is a good soldering iron/workstation. At the very least of the type that allows temperature control. Also, get yourself a good set of tweezers.
Nah... a good adjustable swing arm desk lamp should suffice. I have one with a magnifier that I use a lot.re the vision thing, (LOL) would you recommend a in built model with a LED in it?
got em!Your iron looks fine, and what you need is a fine point, not a wedge.
As for tweezers, there's plenty to find in amazon. Here's an example:
https://www.amazon.com.au/PandaHall-Precision-Anti-Static-Stainless-Electronics/dp/B01GPYMV10
| L | Bi-directional current limiting circuit? | Power Electronics | 51 | |
| C | Schmitt trigger debounce circuit problem(s) | Digital Design | 15 | |
| F | Basic Amp Circuit Question | Homework Help | 6 | |
Capacitor discharge circuit in modern multimeter | General Electronics Chat | 31 | |
| L | Did you ever make a circuit and gift to your loved one? | Off-Topic | 15 |
