No, you do not need a wedge type tip. In fact, using that tip geometry might make things harder.what about my post in reply to you about the soldering iron. do i need a wedge type tip? cos thats a problem on the one ive got. its pointed View attachment 184970
Excellent. You might try to look for some videos out tok thank you here regarding this subject, there's a plenty. But you might want to get started by practicing soldering SMT resistors and caps. The technique is pretty straightforward. Using 60/40 solder, lightly tin one of the pads on the PCB, and then using tweezers hold the part in place and press the iron's tip against both the part and the pad until they're both soldered. After that you don't need the tweezers anymore, just apply a bit of solder (less is more) to the other side of the part and its pad. Easy as that... although it requires a little practice. I normally set the iron at 525°F for that purpose.
The hard part comes when you need to use low temp solder for delicate components, such as ADC chips. But we can get to that later.
Actually, you don't have to look far. Most smt devices include their PCB mounting footprint in their datasheets. Look it up.Thank you Cmartinez.
Could you advise how I mount the inductor pls. Refer as follows:
https://www.coilcraft.com/do3314.cfm
I need a specialised adaptor but I don't know what to Google. Can you help pls.
I assume there is an industry standard for all the various configurations of SMD packages and their respective adaptors. Perhaps there is a publication listing these?
Thankyou very much @cmartinezI forgot to mention that once I position the part on the pcb, I hold it in place while soldering by pressing it (and not by clamping them) down using the same tweezers.
John is right about magnetized tweezers being a nuisance.
I'm going to make a small video today later on and post it here, to more clearly illustrate this process.
Oh OK, well that changes things a little!The voltage from a battery drops as it is used. How soon will the voltage be so low that the LED does not light anymore?
Three AA alkaline battery cells are 4.5V only when brand new and they drop to 3V when the LED probably is very dim.
The current is too high to use little AAA cells or a 9V battery. The LED will dim by itself as the battery quickly runs down.
An ordinary old 555 has a minimum supply of 4.5V and probably does not work when your battery voltage has dropped a little. Use a LMC555 which is guaranteed to work when the battery has dropped to only 1.5V. But most Mosfets need a much higher gate voltage, usually 10V but some Mosfets are "logic level" and work when the gate is 5V.
Many opamps also do not work at your very low supply voltage.
Yes, I did look it up before I posted but I was still stumped.Actually, you don't have to look far. Most smt devices include their PCB mounting footprint in their datasheets. Look it up.
For devices such as those inductors, what I usually do is create a land pattern larger than the one recommended in the datasheet, and then proceed exactly as I would proceed with an SMT resistor or capacitor. That is, I'd make sure the solder touches the sides of its terminals. And in the inductor you're working with, that too is also possible because its terminals wrap up from the bottom to its sides, exposing a narrow area to which the solder can attach itself to.Yes, I did look it up before I posted but I was still stumped.
To elaborate:
SOIC to Dip SMT Adaptors
For the LTC 349 (datasheet attached "DS1") its pretty clear what I need. (Pls see Fig 1). Got it.
However for the SMT power inductor (DO3314 332 - see datasheet "DS2" attached) there are no feet to attach to such an adapter. Please see Fig 2 and Fig 3 below.
Do you know what SMT to DIP adaptor board I can use to get this inductor into my prototyping breadboard circuit?
Many thanks in advance
Mellisa
To answer your question, I don't use adaptors, but rather I make my own PCBs using a process that I developed myself over the years.Do you know what SMT to DIP adaptor board I can use to get this inductor into my prototyping breadboard circuit?
| Thread starter | Similar threads | Forum | Replies | Date |
| L | Bi-directional current limiting circuit? | Power Electronics | 38 | |
| C | Schmitt trigger debounce circuit problem(s) | Digital Design | 14 | |
| F | Basic Amp Circuit Question | Homework Help | 4 | |
Capacitor discharge circuit in modern multimeter | General Electronics Chat | 31 | |
| L | Did you ever make a circuit and gift to your loved one? | Off-Topic | 15 |
