Push on, push off
FroceMaster
Joined Jan 28, 2012
708
-have made this circuit.
When adding 12 v on INPUT, the relay K2 should be activated.
When 12 is removed again K2 is still activated.
When 12v is applied again the K2 should be deactivated.
AlbertHall
Joined Jun 4, 2014
12,625
It would do that except that initial state when power is applied depemds on whether C2 is charged or not. If C2 is discharged when power is applied then K2 will be activated. To avoid this you would need a 'power on reset' circuit.
38,504
Connect C2 to +12V instead of ground (plus side of capacitor to 12V).
The circuit output relay will then be off when the power is applied.
Alternately, add one of the spare inverters in series with the IC2E and the MOSFET.
