You will not be able to provide sufficient drive for even the low current leds with this design.
Listen to @MrChips and drive the leds with transistor or mosfet buffers.
Sure, a separate driver gives you external indicator options but I wouldn't say you can't do it with the right leds if all you need is a PCB indicator.
I use the tiny 0603/0805 low-current SMD leds for direct to pin rx/tx logic indicators as most proper receiver modules and devices have Schmitt trigger inputs. The 1-2mA drive requirement (adjust the current limiting resistors appropriately) is well within most I/O port drive current sink specifications (the MAX chip MCU I/O can easily sink 30mA and still meet proper logic levels). It's common to see i2c pullups in the 2K range for bit-banged gpio, well within the range of low-current led limiting resistors.
