Proper way to joint two AWG 28 wire together ?
meowsoft
Joined Feb 27, 2021
666
Proper way to joint two AWG 28 wire together ?, one is solid and one is flexible, how to joint that wire properly and massively and easely ?, about 200 connections need to be jointed
DickCappels
Joined Aug 21, 2008
10,661
Twist-solder-insulate and you are done. The insulation should be heat shrink tubing so it also offers some strain relief to "soften" then bend at the end of the solder.
meowsoft
Joined Feb 27, 2021
666
How are the conductors arranged? Are the individual or in a multi conductor cable? Are the exposed to the outdoors? Are they in a cabinet?
Individually, that cable came from cat 5e 8 core wire, but connected individually, previously we only use western union and tape, but that joint technique isn't really good
Ya’akov
Joined Jan 27, 2019
10,295
Well, it would help to know how they are being used. Do they have to stand up to the weather? Are they in a cabinet? Are they bundled in any way?
meowsoft
Joined Feb 27, 2021
666
What I might do is to put RJ45 connectors on both ends and use a coupler. Make sure you get the RJ45 connectors for both solid and stranded or the one used for both.
https://www.thebroadcastbridge.com/...4-awg-26-awg-and-28-awg-network-cables-differ
A 110 punch down block https://en.wikipedia.org/wiki/110_block might work, but I don't know if it;s OK for stranded wires.
I'd say solder and adhesive heat shrink but 200 connections, no.
Yes... in one side I use RJ45 and cat5e, but cat5e is connected to 28awg wire individually, I was think to make controller redesign with RJ45 port inside instead individually 28 awg female ports, but now that think isn't possible (because deadline time and cost)
meowsoft
Joined Feb 27, 2021
666
Is in the cabinet, and only small cabinet, about 30 cm x 40 cm x 15 cm (L x W x H)
