Proper Cathode Marking
Conesaw
Joined Aug 12, 2021
I'm pretty new here. Usually just a reader. Looking for help on the marking voltage stabilizer. Zte1.5. I work in the semiconductor industry and a customer says the cathode band should be on the positive side but I disagree. It can be used in reverse bias but I don't see anywhere that says it should be marked in reverse. Any thoughts?
ericgibbs
Joined Jan 29, 2010
21,654
Hi Con,
Welcome to AAC,
This is what Google states.
These are results for voltage stabilizer zte 1.5 polarity marking
Search instead for voltage stabilzer zte 1.5 polarity narking
E
AI Overview
The end of a ZTE1.5 voltage stabilizer diode marked with the cathode ring must be connected to the negative pole of the supply voltage.
Polarity Details for ZTE Diodes
    • ZTE1.5 and ZTE2: The banded end (cathode ring) connects to the negative pole.
    • ZTE2.4 through ZTE5.1: The banded end connects to the positive pole.
SamR
Joined Mar 19, 2019
5,549
On axial foil wrapped and unmarked capacitors the outer foil side goes to ground. After testing to determine the foil side end, I mark the foil side end.
