Circuit doesn´t behave properly
Rufinus
Joined Apr 29, 2020
325
Hi everyone.
I finally finish the circuit I asked about some days ago. This time I have been carefull and I think there are no typos and I have labeled each component. It is part of a triode tester and this is the power supply for the anode/plate. It is supposed to give 0 to 300V.
The problem is, it only gives 0 to 181V. Since is inside a cage, I have removed the PCB to run some tests. These tests have been made with 230V instead 300V because the 300V transformer is inside the cage and It is difficult to do the tests in that way. Some results:
- It keeps giving 181V maximum, no matter if I ran it with 300V or 220V
- At low voltages, R1 gets very hot. It is rated 1 watt
- D6 have a voltage drop of 0,028V
- The original potentiometer was 200K but mine have 180k. I have made new tests with a 220k potentiometer and It goes to 211V
- I repeated the test with 250V and only goes up to 213V output
I suffer from severe ADHD and my first idea was I made a bad connection, but I have checked all the connections 3 times following then in the PCB and marking on the printed image of the circuit to be sure and everything looks fine.
I´m clueless about this. Could anyone help me?
ronsimpson
Joined Oct 7, 2019
4,884
This circuit is not good, but I will try to help.
Rv1 & R7 makes a voltage divider. Very likely 180K is +/-20%. So maybe test the value of Rv1. I see you found that problem. You can try reducing R7 by 10% and see if you are getting more voltage. Place a 36k across it. This might all be a voltage divider problem AND a problem that the Gate to Source turn on voltage of your MOSFET is not well known.
schmitt trigger
Joined Jul 12, 2010
2,280
Rufinus: The schematic has many fatal errors:
-it has no voltage reference.
-to obtain the full output voltage without a floating auxiliary supply, you require a depletion, not an enhancement, series pass device.
-a Mosfet designed for switching operations, like the IRF840, does not have the required SOA to operate continuously in the linear mode. More so, when the output voltage is low.
You want to see what a proper vacuum tube power supply circuit looks like? Go to;
Tubecad dot com slash august99
And read from page 8 onwards.
schmitt trigger
Joined Jul 12, 2010
2,280
Additional comments;
The website that I linked likes to keep all their circuits using vacuum state devices. Everything can be replaced with modern semiconductors, but I would still urge you to keep the series pass device as a vacuum tube.
Why? Mostly because of the SOA indicated earlier. Tubes take abuse that would destroy even a rugged semiconductor in milli seconds. If the plate starts glowing an intense red, you have time to turn it off.
ronsimpson
Joined Oct 7, 2019
4,884
Q2 data sheet: Under this test condition it might take 2V to 4V to turn on the transistor. Most likely it will take about 3V but could be 2V or 4V. This adds errors. If the next transistor came from a different batch, it would act different. Probably your SPICE is assuming a Typical value for gate-source threshold voltage. The Gate threshold voltage is not temperature stable.
Here is a more typical error amplifier in a power supply. V2 is a 1% or 0.5% voltage. We know it is 2.5V.
Please don't give up on this supply. It will probably work for you just fine. It does not follow "good engineering practice."
Hi everyone.
Measuring the DC voltages at Q1 gate, Q1 source, Q2 gate; Q3 base, collector, and emitter. Also measure the voltage across D5, D6, and D7 and R1. These measurements will probably identify where the problem is.
Rufinus
Joined Apr 29, 2020
325
Thank you all for your help and concern.
The circuit it is not mine. It should work, because who give it to me have build it with good results. But maybe he built it with changes, I don´t know.
Ok, it seems the potentiometer has a low voltage, but, despite that, if I go for a higher value, the problem of R1 overheating will continue if I put the potentiometer in lowers values.
At 250 VAC input and a 220k potentiometer I have
EDITED R1, with the potentiometer at max 140V and min 353. In the second case it disipates 1,2watt and that resistanse it is suposed to be 1/2watt
D6 0,028
D5 3,2
D7 3,4
Q1 Gate at max 219 and min 6,81. Source max 216 min 3,6
Q2 gate max 3,4 min 3,5
Q3 Emitter max 316 min 3,5. Base max 215 min 3,5. Colector max 218 min 6,8
And with the voltages of LTspice with 230VAC from the mains, with 300k resistances in place of the potentiometer and 30k resistor as load. I owerwrite in red the values I get
Best regards
ericgibbs
Joined Jan 29, 2010
21,641
Hi Rufinus
Do have a clear photo shot of your circuit assembly, that you could post?
E
R1 potentiometer at max 140V and min 353. In the second case it disipates 1,2watt and that resistanse it is suposed to be 1/2watt
Who suggested R1 should be a potentiometer?
Rufinus
Joined Apr 29, 2020
325
Sorry, I don´t speak english very well and sometimes I express myself in a bad way
I meant the voltage across R1 with the potentiomeeter at maximum and minimum value. Because only gets very hot when the potentiometer is a lower values
About the circuit, in the PCB, inside the green lines are the circuit I ask about. Below is the filament power supply and the transconductance meter circuit
I have check everything with a 30X magnifying glass looking for shortcircuits. Also I have used insulating coating (a spray)
ericgibbs
Joined Jan 29, 2010
21,641
Hi R,
Tested a simulation with R8=80K and the R1 resistor overheats at ~1 Watt
R8 =40k R1 =1.4 Watts
What range of B+ voltages do you require??
E
Rufinus
Joined Apr 29, 2020
325
up to 300V
At least the voltage meter included in the circuit (but I removed to simplify) it is up 300V
Rufinus
Joined Apr 29, 2020
325
I don't really have much idea about electronics. I'm making some old triodes (blowing the glass, making high vacuum inside...) because I want to make a radio from zero.
This one is the last I made and doesn´t work very bad
I´m building this meter to check the triodes I make and improve its performance.
My knowledge in electronics it is very limited (but I´m learning). So, no idea about what you ask me about.
And the lowwest voltage i think it is 30-50 volts,
ericgibbs
Joined Jan 29, 2010
21,641
hi Rufius,
This circuit simulation uses a 500k potentiometer to set the +B voltage.
Add the R8, 27k and change R7 to a 5k6.
As you can see the plot shows a voltage +B range of ~30v through to ~ 300v.
Increase the wattage of R1 to 3Watt,
Do you follow OK.???
E
Rufinus
Joined Apr 29, 2020
325
Thank you for all your help and effort!
As soon as I get the components I´ll post the results
And also another question. To power the filament, I have this circuit, that works fine
Filaments works from 3 to 6 volts and 1 to 3 amps. The Lm338 is in the picture of the PCB under the green sector. Do you think that heatsink is enough?
thank you
ericgibbs
Joined Jan 29, 2010
21,641
hi Rufius,
Worst case is 3V at 3 Amps, creates 12 Watts heating of the LM338, you need a suitable heatsink size.
E
Added PDF.
@Rufinus
Footnote: the LM338 requires a 3V differential between the Vinput and the Vout.
This means the Vin DC level must be 9Vdc in order to achieve 6Vdc out
The 6.3Vac transformer, rectified, allowing 2V for forward diode voltage drops will only give ~6.9Vdc
Link.
https://www.google.com/search?client=firefox-b-d&q=design+a+12+watt+heatsink
