Programmer is not responding, not in sync
be80be
Joined Jul 5, 2008
2,395
It still be nice to see what your doing.
You can't have anything hooked to pin 0 and 1 or the reset
A picture of your board
djsfantasi
Joined Apr 11, 2010
9,237
We have several posts and many suggestions. One of which I have not seen confirmed.
Are you running the Arduino IDE as Administrator?​
I have had similar problems with the IDE on Win 10. There are separate steps that must be taken each time to run the IDE, unless specific steps are taken the first time you install.
I start by installing a shortcut on the desktop. Then, before running it, I open up the desktop properties and under Security, I check the box to run as Administrator.
Then, I copy this customized shortcut to wherever I may run the IDE. Desktop, taskbar and from the apps menu. I also ensure to delete any original shortcuts.
When NOT running as Administrator, the drivers do not execute successfully and prevent the IDE from communicating with the board.
Yes, as mentioned, the board runs the old sketch. The only aspects of that post that were abnormal were the three I showed.
OK, when you say it "runs" the old sketch, you mean that it is still running the last sketch that was flashed, as soon as you power up...not that it loaded and ran that sketch today.
Tomorrow's a new day...but I am still not convinced that it is bricked...not yet anyways :)
Terrypin
Joined Feb 5, 2016
113
From post #29:
"The chip is plainly working, at least to some extent, as it's still flashing the last sketch uploaded two days ago."
From post #29:
Yes, I read that...and to me, when you say "flashing" it means that you are uploading and flashing the program. It only gets "flashed" once and then it stays there and is executed every time you power up... until you flash another program over it. It's easy to misunderstand and be misunderstood on forums.
Terrypin
Joined Feb 5, 2016
113
Fair point. I was actually using 'flashing' to mean 'blinking'. Flashing on/off the built-in LED driven from pin 13. The upload was a minor variation of Blink.ino (enough to distinguish it from the built-in sketch).
I assume your 'flashing' is another term for 'uploading', similar to flashing new firmware?
You can try this test (as described here). I just did this to test it out. I first loaded and ran Blink - selecting, of course, the correct port in the IDE. Then I unplugged the USB cable. I did not close the IDE.
I put a jumper from 0 to 1 - that's TX to RX and a second jumper from GND to RESET. Then I plugged the board back in. I heard the familiar "thunk" from the port recognition on my WIN 7.
Then I plugged the USB cable back into the UNO. The LED bit that was blinking stopped blinking - as it should.
Opening up the Serial Port window in the IDE, I type some text, click return and it appears in the output window.
As soon as I remove the reset jumper (and the TX to RX), the UNO resets and then starts the blink program again.
This means that I have the correct port selected and Windows agrees with that.
What do you get?
Terrypin
Joined Feb 5, 2016
113
Raymond,
Thanks, but my new UNO arrived promptly this morning and I've just tested it successfully with a couple of sketches. So it was indeed a hardware issue. I must have damaged it somehow. :(
I'm off to the shed now but I'll be very surprised if it doesn't also work fine on my XP PC. I'll report back later.
Raymond,
I'm glad the new one came in and it works.
It would be good to know what you did to brick it, IF you did anything. It is possible that it went bad through no fault of yours. Will you send it back?
Anyways, enjoy the shed.
Terrypin
Joined Feb 5, 2016
113
Thanks Raymond. The new UNO worked fine on the XP PC. (Once I'd remembered that for some obscure reason it needs to run in Win 2000 Compatibility mode.)
Yep, wish I knew for sure what caused it, but I suppose it had to be the solenoid work, as per post #20:
"I can't remember exactly but at one stage I did drive a solenoid (with protective diode in parallel) via a power MOSFET. That was working OK. Then a bit later after editing that code the described symptoms arose."
Simon0362
Joined Sep 17, 2011
4
Just been down the same frustrating route.....
Fixed the problem by setting the processor to ATMega328 (Old Bootloader) - I was unsuccessfully using the 'standard ATMega'
Very old thread but I hope this might help someone.
BR
Simon
Terrypin
Joined Feb 5, 2016
113
Thanks for the feedback Simon.
Although my issue turned out to be down to my somehow zapping the USB interface, the thread is packed with valuable trouble-shooting tips. Thanks again to all who contrubuted, particularly to @Raymond Genovese and @be80be.
Terry, UK
(Still an Arduino novice, but learning gradually.)
