I showed one of the front in my first post to this forum on 18th May, #72 here:Could you post 2 good pictures one of the front and one of the back of your uno
Yes, as mentioned, the board runs the old sketch. The only aspects of that post that were abnormal were the three I showed.When you plug the UNO in, using the USB port on the Win 10 machine, is the green power light illuminated as in the picture below?
Yes. Tried both modes.We have several posts and many suggestions. One of which I have not seen confirmed.
Are you running the Arduino IDE as Administrator?
OK, when you say it "runs" the old sketch, you mean that it is still running the last sketch that was flashed, as soon as you power up...not that it loaded and ran that sketch today.Yes, as mentioned, the board runs the old sketch. The only aspects of that post that were abnormal were the three I showed.
I'm trying to upload any sketch!It still be nice to see what your doing.
As mentioned, nothing is connected to any pin.You can't have anything hooked to pin 0 and 1 or the reset
See my two replies earlier.A picture of your board
From post #29:OK, when you say it "runs" the old sketch, you mean that it is still running the last sketch that was flashed, as soon as you power up...not that it loaded and ran that sketch today.
Tomorrow's a new day...but I am still not convinced that it is bricked...not yet anyways![]()
Yes, I read that...and to me, when you say "flashing" it means that you are uploading and flashing the program. It only gets "flashed" once and then it stays there and is executed every time you power up... until you flash another program over it. It's easy to misunderstand and be misunderstood on forums.From post #29:
"The chip is plainly working, at least to some extent, as it's still flashing the last sketch uploaded two days ago."
Fair point. I was actually using 'flashing' to mean 'blinking'. Flashing on/off the built-in LED driven from pin 13. The upload was a minor variation of Blink.ino (enough to distinguish it from the built-in sketch).Yes, I read that...and to me, when you say "flashing" it means that you are uploading and flashing the program. It only gets "flashed" once and then it stays there and is executed every time you power up... until you flash another program over it. It's easy to misunderstand and be misunderstood on forums.
I'm glad the new one came in and it works.Raymond,
Thanks, but my new UNO arrived promptly this morning and I've just tested it successfully with a couple of sketches. So it was indeed a hardware issue. I must have damaged it somehow.
I'm off to the shed now but I'll be very surprised if it doesn't also work fine on my XP PC. I'll report back later.
