USB2514B/M2 Hub Downstream Port Communication Issue (EC200 Programmer)
akash123kumar
Joined Aug 13, 2025
11
I am currently encountering an issue with my custom circuit that utilizes the Microchip USB2514B/M2 USB 2.0 Hub Controller for programming an EC200 cellular module (using its USB interface). Setup Details
  • USB Hub Controller: Microchip USB2514B/M2 (USB 2.0 Hub)
  • Target Device: EC200 Cellular Module (Programming/Debug interface)
  • Downstream Port Protection: USBLC6-2SC6 (ESD Protection Diode Array)
Problem Description
When the EC200 module is connected to one of the downstream ports of the USB2514B/M2 hub, the expected USB data signals (D+ and D-) are not being properly detected or communicated at the downstream port pins of the USB2514B/M2 (specifically pins D_N and D_P for the respective port).
In other words, the host PC does not enumerate the EC200 device that is connected through this hub port.
Protection Circuitry Details
I have implemented ESD protection on the downstream port using the USBLC6-2SC6.
  • The USB signal lines (D+ and D- from the downstream connector) are routed through the USBLC6-2SC6.
