hello,
i bought one of these
http://www.ebay.co.uk/itm/USB-2CH-2...919203?hash=item3a8c98ad23:g:pTUAAMXQlgtSysjQ
and i plugged it in to a half wave rectifier circuit that i am learning about and got 4 volt peak to peak. the sine wave didnt look too great either. the frequency was correct at 50Hz. i had the probe set to 1x. i tested the dso using the 1kHz test signal and that seemed ok. the circuit i built is a 240v / 12v transformer 6va. i measured 16 volts without a load. i tried to measure this using the oscilloscope and got the 4 volts mentioned above. am i doing something wrong (which is my guess) or is the dso cheap rubbish (another guess).
any help would be great, hope your all doing well by the way!!!
thanks
simon
thanks
simon
