My grandmother recently let me have her Centrex model KH-5511 home stereo system, manufactured sometime in the 1970s. I have taken it upon myself to both repair and modify it to make it better and more suited to my needs. Conveniently, she still had the original user manual, complete with a full circuit diagram (if only consumer electronics still came with those). The stereo was originally only specified to provide 4 watts per channel RMS at 8 ohms. I did some calculations, and figured that by replacing the main power transistors, as well as a few components in the power supply circuit, I would be able to increase this to 20 watts per channel at 4 ohms. The amplifier is a two channel class AB amp.
I ordered what to my knowledge would be the best components for this, and replaced the old ones with these, as well as adding larger heat sinks. Everything seems to function, and it sounds very nice and loud, but I am having problems with thermal runaway. Even with music playing at the lowest audible volume, after about a half hour the temperature of the transistors had reached 60 degrees C, at which point I turned the power off. I glued the biasing diodes to the power transistors with thermal adhesive, similarly to how it had been with the old transistors, so I don't think that a temperature differential between the two is the problem. I am assuming that the problem lies either with the thermal characteristics of the diodes not being compatible with those of the transistors for use in an amplifier, or that the other circuitry that is responsible for biasing was designed specifically for the previous transistors, and needs to be adjusted. However, I may be totally wrong, my knowledge in this area is strictly self-taught.
Either way, I certainly do not have enough knowledge to know how to fix this, regardless of the reason behind it. I was hoping that someone would know of a way to stop this from happening, preferably by replacing components already in the circuit.
The portion of the circuit diagram describing the amplifier in this stereo is attached. (It also includes a tuner and a tape player/recorder in the same unit.)
The main things I replaced were D1, D2, D3, D4, Q11, Q12, Q13, and Q14. I replaced the diodes with 14N003-T diodes, with this datasheet. Q11 and 12, the NPN transistors, I replaced with TIP41AG transistors, and Q13 and Q14, the PNPs, with TIP42AG. Both have the following datasheet.
Though I am not sure that it is important, I also replaced R63, R64, R65, and R66 with 0.22 ohm 5 watt wirewound resistors, part number 280-CR5-0.22-RC, with these specs. I replaced D7 with part number RS1001M, a 10A bridge rectifier with this datasheet. I replaced C55 with two 15V 14000μF capacitors in series that I bought at a surplus store, in order to reduce the background hum (they were successful in doing so).
Though it is a lower priority, I also noticed that the new transistors seemed to provide much more bass than the previous ones, so that even when the bass was set to zero, it was being significantly boosted from the amount fed into it. I will do some tests to confirm this and find out to what to degree it is happening, but I would appreciate any suggestions as to how to fix that. Like I said, it's a low priority; lots of bass certainly isn't much of a problem, but I would prefer that setting the bass at zero meant the bass actually was at zero.
Thanks in advance!
GeorgeTR
Thanks in advance!
GeorgeTR
