printing a circuit board
jacbk612
Joined Feb 8, 2017
47
Hello, can anyone recommend a tutorial on how to make a printed circuit board and is there any software out there to help design the board?
Thanks,
Jacques
jacbk612
Joined Feb 8, 2017
47
Robin, thank you for the links. I know google, and I have used it for this search. What I use this forum for is to get expert opinion on subjects that I know little about. A recommendation by an experienced member is worth much more than any number of google searches.
Jacques
www.pumpfundamentals.com
AlbertHall
Joined Jun 4, 2014
12,626
Making good PCBs is not that easy until, after lots of practice and plenty of unusable boards, you develop the skill.
I have just had a board made by this guy and I am very pleased with it and pleased with the price.
jacbk612
Joined Feb 8, 2017
47
Thanks, I'm not sure if I want to invest all the time required to make my first PCB. I'm working through this link, is this a guy called maticvodicar from Slovenia?
AlbertHall
Joined Jun 4, 2014
12,626
That is the name he uses. I don't know if it is his actual name. I ordered the board on 20 Feb and received it 27 Feb and there was a bit of to-and-fro about exactly what I wanted included in that time.
jacbk612
Joined Feb 8, 2017
47
I've just tried Designspark PCB, it seems at first quite complete with a large library. Unfortunately it does not have a voltage regulator LM317 of the style that I am using. So I have to create a part through the wizard. There are many youtube tutorials that explain the process, unfortunately they seem to be using previous versions of the software that do not match at all what I am seeing on my screen.
So! Steep learning curve, maybe even off the cliff. No tutorials with the current version. I'm going to try PCB123 and see what happens.
Jacques
spinnaker
Joined Oct 29, 2009
7,830
Jacques
You will find you will need to create parts in most of these software applications. I wish there was a standard for these files so they can be shared across applications.
Give Diptrace a try. In my opinion a very small learning curve.
hp1729
Joined Nov 23, 2015
2,304
Thanks,
Jacques
You may want to decide where you will have the boards made and see what software they like.
