Preamp
Paul Bober
Joined May 11, 2024
86
Certainly it is some kind of amplifier, although I see nothing indicating the input or output in the first post. AND the presentation is indeed non-conventional.
Substitute the signal generator with a guitar. The resistor that is labeled ZL and 10K is not an actual part in the circuit. ZL and 10K refer to the load impedence, placed on the output of the op amp.
Wendy
Joined Mar 24, 2008
23,821
Are you questioning this circuit,or what? Could it be you are trying to brag? A little context would be nice.
28,296
I see nothing wrong with the circuit. It should function and provide gain. The gain will be quite high, but with a 9 volt battery and the input biasing, the stereo system will be the first section to produce distortion, well before this circuit starts clipping.
The circuit is a variation of the classic single supply non inverting amplifier.
For use as a guitar adapter the Twill need to provide shielding and adequate ground integrity.
Paul Bober
Joined May 11, 2024
86
The circuit has a gain of 4. RCA line inputs on home stereos are -10 db, and input impedance can range from 10K - 50K per channel.
