Hi everyone,
I am a complete beginner in electronics and PCB design, I relied heavily on pre-existing projects (which however used one PCB for 2 piezo transducers, while I'd need the flexibility of one for each, as well as possibly less noise), so please forgive any obvious mistakes in my schematic or layout. It seems to pass KiCad errors, however before sending this board out for manufacturing/testing, I would really appreciate it if some experienced eyes could check whether the circuit will actually work as intended and if there are any improvements I should make.
There are 15 electronic components on it, so hopefully it'd be straightfoward to review, despite my untidy layout.
What the circuit is supposed to do:
What I would love your feedback on:
I have attached PNG images of the schematic, top copper (F.Cu), bottom copper (B.Cu), and 3D view, along with the archived KiCad 10 project (.zip) in case anyone wants to inspect the files directly.
Thank you very much in advance for your time and patience!
- a (hopefully) low-noise, high-input-impedance preamplifier designed to read weak signals from a piezoelectric transducer (connected to J1).
- It runs on a single +12V DC supply (connected to J2), using one half of an OPA1656 dual op-amp (U1A) to generate a mid-rail virtual ground (VGND at +6V) and the second half (U1B) to amplify the sensor signal.
- Amplifying 11 times (20.8 dB) due to ratio of resistors R4 and R3.
- The amplified analog signal goes out through J2 (SIG_OUT), while D2 provides reverse-polarity protection on the +12V input.
- Target Bandwidth / Filtering: The amplifier is intended to pass signals in the [10 Hz] to [192 kHz] frequency range, with an appropriately selected capacitance given by the piezoelectric transducer, but I hope it could work with any transducer, while just accepting the different cutoff frequencies.
- Schematic & Analog Design: Will this circuit actually work properly with a piezo/underwater sound sensor (after waterproofing)? Are the input biasing, virtual ground (VGND) stability, filtering, and gain stages properly designed, or is there any risk of oscillation, excessive noise, or signal clipping?
- PCB Layout (2-Layer): Are my ground planes, decoupling capacitors, and trace routing acceptable for a low-noise analog signal, or did I make any mistakes?
- Capacitor Selection & Values: Could you please verify if the capacitor types and values I chose (for AC coupling, filtering, and power supply decoupling) are appropriate for a low-noise piezo/hydrophone circuit, or if I should change any values or dielectric types (e.g., C0G/NP0 vs. X7R to avoid microphonics/piezoelectric noise from ceramic capacitors)?
- Suggested Improvements: Are there any component values or small layout tweaks you would strongly recommend before ordering the boards?
