Power Converter (LM2596) simulation
remi_for
Joined Jan 30, 2016
6
Is there anyone who know if there is a good software to simulate a Power Converter curcuit, were I would like to use the LM2596?
I tried to find it in Multisim, but it was not there.
eetech00
Joined Jun 8, 2013
4,715
Awesome! What is LTSpice? Is it a free software? Easy to use, like multisim?
LTspice is a free simulator developed by Linear Technologies. It's has a steep learning curve but is probably the best free simulator available. One you understand how to use it, it's easy to use.
remi_for
Joined Jan 30, 2016
6
Thanks! I installed the software, and tested it. It works good, and the software looks pretty good. Excited to try it more.
You sad you have a simulation of the LM2596? How should I find it?
Alec_t
Joined Sep 17, 2013
15,136
I'd suggest you join the Yahoo LTspice User Group. They have libraries of all sorts of sim models for free download. You can add models (*.sub and *.lib files) to the standard LTspice 'sub' folder, and add their symbols (*.asy files) to the LTspice 'sym' folder (or sub-folder thereof).
eetech00
Joined Jun 8, 2013
4,715
Hi Alec_T
Last time I looked they didn't have an LM2596 model. So I made one.
eetech00
Joined Jun 8, 2013
4,715
I only have an LM2596ADj adjustable version at the moment (see attached image). But its easy enough to make a fixed version if you need one.
Which one do you need?
remi_for
Joined Jan 30, 2016
6
Thanks a lot :)
I need a LM2596. I am using it for a project were I would like to test if I could convert a voltage who is between 9 - 7, down to 5 V / 3 A for a load.
The datasheet is the one who is attached.
eetech00
Joined Jun 8, 2013
4,715
Hi
I've created a subckt file containing the Fixed output LM2596 series regulators. It also includes the adjustable regulator. Just add the symbol to your schematic and set the value field to one of the following:
LM2596_03, LM2596_05, LM2596_12, or LM2596_ADJ
Have fun.
remi_for
Joined Jan 30, 2016
6
Hi
Have fun.
Thanks a lot eetech00! Im allready have a lot of fun! :D
But one question: What are the Inrush Input Filter Model for? To regulate an good input volatge?
eetech00
Joined Jun 8, 2013
4,715
Its just to slow the input current rise when input power is initially applied. You probably don't need it.
mcj74
Joined Jan 10, 2007
8
Hello eetech00, thank you for making this model. I tried it with the newest version of LTspice and got:
This was after changing all of the PULSE(...) statements in LM2596xx.txt to include a missing 5th parameter {VTFALL}. It simulates now, but does not operate correctly. Could you investigate? Thank you.
eetech00
Joined Jun 8, 2013
4,715
Hi
Here is the latest version attached.
