Power Circuit Design - Car powered Apple AirTag
UCanDoIt2
Joined Sep 9, 2023
7
Overview - I would like to install an Apple AirTag in a vehicle and have it gets its primary power from the vehicle's 12V battery. In the event that the 12V Battery is disconnected, I would like for a backup 3V Battery to continue to provide the power required to run the AirTag.
Approach - Here is what I think I need for this circuit solution to achieve
  1. The Apple AirTag runs on 3V and about 230mA.
    1. I would like to hide this unit where it is hard to get to, the coin battery typically lasts 1 year. I would like to power off the 12V
    2. I will be removing the AirTag speaker to help make it's location obscure.
  2. I would like the Vehicle Battery to be the primary power source of the Apple AirTag.
  3. Use of a Buck Converter to bring the Auto Battery 12V down to 3V (actually 3.7V for Diode voltage loss)
  4. I would like ton include a 3V Battery for backup in case the Vehicle Battery is disconnected.
  5. Place a 3V LIR2032 Coin Battery in parallel to the Buck Converter power supply
    1. Wanting the 3V Battery to sit idle and not provide any power until needed.
    2. If it is not used, there should be no need to trickle charge it.
    3. Trying to avoid placing another Diode in the 3V Battery circuit due to slight voltage drop.
    4. The LIR2032 is a Re-chargeable version of the CR2032, as I believe the current diagram may attempt to charge this battery.
  6. Place a Diode between the 3V Battery and Buck Converter for converter protection.
  7. The AirTag does require 3V to 2 separate terminals and Ground to 1 terminal.
Current Diagram - Here is my current diagram for your review. Looking for your suggestions.
Thank you in advance for your review.
Mike
BobTPH
Joined Jun 5, 2013
11,615
That circuit will cause the battery to supply all the power until it is half discharged. Is that what you want?
Ian0
Joined Aug 7, 2020
13,227
The battery is a CR2032 with a capacity of 210mAh, which is claimed to last about a year. So the average current is 210mAh/8670 hours = 23uA
A switched mode will be less efficient than a linear regulator at that sort of current, so use something like a LP2951 to supply 3V to the airtag. Then supply it from its standard CR2032 via a schottky diode (or a P-channel FET ideal diode circuit). That would give you a year's use when disconnected from the vehicle battery - won't that be enough?
UCanDoIt2
Joined Sep 9, 2023
7
When you say "will cause the battery"... are you talking about the 12V car battery? My thoughts are that it should draw all of it's current from the 12V battery. That battery is recharged every time I use the vehicle, so let's assume it will stay at 12V+.
UCanDoIt2
Joined Sep 9, 2023
7
Additional Details - The original post will not allow me to edit, so here are some additional details.
I was researching Car alarms and they all have GPS "add-on" features at a cost and with a monthly subscription. Therefore, why no use the Apple AirTag. As I previously mentioned, I would like to hide the AirTag deep under the dash and with an expected 1 year battery life, why not have it powered by the car's battery.
My original design only included the Buck Converter and was straight forward. I wanted to add the backup as an added feature and for me to figure out how it could be done. My research did not uncover a definitive answer. Without wanting to give up, I am turning this into a learning exercise on my part.
If someone stole the vehicle AND they have an iPhone... they would get a message that an AirTag is following them and they would have the opportunity to have the AirTag identify itself by making a chirp (this is why I removed the speaker).
But now that they know an AirTag is present and the Car Alarm, they would highly consider disconnecting the battery. I would like the AirTag to continue to operate with the 3V coin battery.
My concerns for the overall circuit are:
  1. If the 3V coin battery is truly in idle and not being used, it should be good for 10-15 years.
  2. I was not looking for this solution to provide any "re-charging" functions to the 3V Battery.
  3. I did not want to place a Diode to block the 12V from charging the 3V as that would drop the Voltage of the 3V when it was in use.
  4. Without this extra Diode, will the 3V attempt to charge, over-charge, Explode, CATCH FIRE?
  5. I was hoping that as long as the 12V Battery in connected, that it would provide the energy for the AirTag and the 3V would be idle.
Is there a better method to what I am wanting to do? Can you sketch (napkin is perfectly fine) and provide a better circuit?
BobTPH
Joined Jun 5, 2013
11,615
No, I am talking about the rechargeable lithium battery. When fully charged it is 4.2V, so the diode is reverse biased and will not conduct anything from your buck converter. The power will come from the coin cell until its voltage drops to 3.7V. At that point it is half discharged.
And, if you are worried about the the voltage drop, what do you think the battery voltage is at near the end it’s 1 year life? Hint: it will be down by more than the 0.3V drop you can expect from a Schottky diode.
So my recommendation is to use a normal, non-rechargeable battery, use two Schottky diodes and lower the buck output to just above the voltage of a fresh battery.
UCanDoIt2
Joined Sep 9, 2023
7
Thank for the explanation and suggestion!
I have revised my diagram to what I believe you are suggesting. Changes are in Red.
1. Using 2 Schottky Diodes. I placed them in the orientation that made sense to me. Is the Diode number OK?
2. Swapped out the LIR2032 3V to a CR2032 (non-rechargeable)
3. Plan to adjust the Buck Converter output to 4.3V. I assume that will make this the primary power source.
Many thanks for your help. Does this appear to be correct?
BobTPH
Joined Jun 5, 2013
11,615
4.3 is too high, that would’ve give about 4V to your AirTag, which might be okay, but might damage it or shorten its life. I would measure the new fresh battery and add about 0.2 to that.
UCanDoIt2
Joined Sep 9, 2023
7
Thank you Bob. I was going off your note of that battery having 4.2V fully charged. I will measure the actual and add 0.2 as your mention. That is a great approach.
Did I get the Diodes illustrated in the correct position and orientation? Many thanks! Mike
SockSPDT
Joined Mar 28, 2021
4
You probably already know that you can get a linear regulator that draws way less then the idle current of any buck converter I have read about recently (75 uA for lnear).
Check out LP2950L-33-T92-R
Hi Dick, I found this thread when researching the same vehicle theft tracking application as OP, but I was planning on figuring out how to use a buck converter and an 18650 cell.
Your solution using a linear regulator does seem a lot more elegant, and compact. This is for my motorcycle and being compact is good.
Could I ask how would I go about replacing the buck converter in this schematic with the linear regulator you suggested:
I'm afraid my circuit knowledge dwells at the shallow end of the pool, with floaties.
DickCappels
Joined Aug 21, 2008
10,662
Pretty simple, on the surface at least.
Remove the buck converter circuit and connect the linear regulator as follows:
Your Schematic Linear voltage regulator
12Vin ==> Input
Gnd ==> Ground
4.3 Vout ==> Out
Double-check to see whether the voltage supplied to the AirTag is enough for the normal operation. I expect the output to the AirTag to be about 2.3 volts; you might need to adjust the output voltage of the linear regulator.
michael8
Joined Jan 11, 2015
472
Why 1N5817? Those might leak in the mA which is way more current then you want going into the coin cell. Try something
like 1N4148 (Si small signal diode) which max leakage is in the uA.
Also beware that the car electrical system is subject to spikes, overvoltages & reverse voltages -- you need to be able
to avoid your circuit dying if these happen.
https://www.seventransistorlabs.com/Articles/LoadDump.html
There are 3 terminal linear regulators which are designed to handle this for the auto market.
