Pololu - step up/down voltage regulators - experience
thor21
Joined Sep 29, 2024
435
hi @sghioto , thanks
well as i am using 5V , 1-2A devices on 7m cable which is 1mm2 (core) the drop is 1.5V, in case i use 1.5mm2 (core) its 1V
i cant have drop bc usb devices are browning, rebooting etc..
sghioto
Joined Dec 31, 2017
8,758
I would think the S13V30F5 module should work OK.
How many devices are being powered?
What is currently suppling the 5 volts?
sghioto
Joined Dec 31, 2017
8,758
@sghioto
i bought
all mean well HDR series
1x 5V (adjustable 4-6V) 6.5A
1x 12V (adjustable 10-14V) 4.5A
1x 12V adjustable 1.25A
These are the power supplies you are using currently, correct?
Anyway to install a beefier 7m power cable?
A 10 gauge two conductor cable at 7m would only drop 0.26 volts at 6.25 amps, would that work?
thor21
Joined Sep 29, 2024
435
yes, basically i wanted to get rid of all PSU from devices like Alexa, blink cam etc... so "centralize" to 3 PSUs
so it implies 10 gauge for 5V
and 10 gauge for 12V
4 cores, so its gonna be pretty thick (20mm):(
dont know whats a better approach like to go that "thick" route or mess up with regulators?
@sghioto but happy for any recco.
Or in case i find extra money, is it also good with regulators? I am afraid of the heat from these devices ie regulators.
sghioto
Joined Dec 31, 2017
8,758
How are you figuring 20mm?
A 10 gauge wire is 2.59mm in diameter.
A 14 gauge cable would more then sufficient for 12 volts at 4 amps. Drop of only 0.42 volts.
Another thought, since the Mean Well supplies are adjustable why not adjust the output voltage to compensate for the drop?
thor21
Joined Sep 29, 2024
435
@sghioto well that was ma innitial though to buy psu that u can increase voltage as a compensation for a drop. But drop happens under load so u can't send 6v to 5v usb device as u can damage it, same with 12v devices.
Thx
thor21
Joined Sep 29, 2024
435
Multiple media devices
Vero4k
Fire cube
Blink camera
Switch
Etc
I bought 6mm2 cables for 5v
4mm2 cable for 12v branch, each 7m long
sghioto
Joined Dec 31, 2017
8,758
The 6mm2 cable would drop 0.26v at 6.5 amps on the 5 volt line.
The 4mm2 cable would drop 0.24v at 4 amps on the 12 volt line.
Would those voltage drops be acceptable at full load?
