Polarity switching and amplification of square wave?
electronice123
Joined Oct 10, 2008
350
I need to build a circuit which does the following:
20kHz square wave amplified to high voltage with a transformer which has both a positive and negative output. I need the outputs to switch polarity every pulse.
How can this be done?
KL7AJ
Joined Nov 4, 2008
2,229
A step up transformer with a center tap can do that, if it's carefully terminated.
eric
KL7AJ
Joined Nov 4, 2008
2,229
Can you explain in detail how that works?
You can generally pass a square wave through a transformer if you avoid any self-resonant frequencies, and it's got enough bandwidth to pass at least the fifth harmonic. For example, at 20 KHz, you want a transformer that's flat up to around 100KHz. Most of your high quality switching power supply transformers can do that. You need to put a matched load resistance on it, however, or it may "ring" which may or may not be a problem. How critical is it to have a very sharp square wave on the output?
eric
electronice123
Joined Oct 10, 2008
350
The high voltage will be used to charge a capacitor with a polar liquid dielectric. It has been said that the liquid dielectric can be heated, I'm doing it for a science experiment but I don't think it will work.
500V-1000V will be plenty
bertus
Joined Apr 5, 2008
23,014
How many current will flow in the dielectric ?
You could use a inverter like schematic with a CT transformer like eric siad.
Here are some schematics used for fluorescent lamps.
http://ludens.cl/Electron/Fluolamp/fluolamp.html
The last one is designed for ca. 25 khz.
(You can drive the transistors with a controlled oscillator in stead of selfoscillating).
Greetings,
bertus
Joined Apr 5, 2008
23,014
So you end up with 50 to 100 Watts.
Then the proposed schematics I shown you are to small.
Perhaps you can scale it up.
Greetings,
