PMOS on Zeta Converter
Firenze02
Joined Sep 1, 2018
47
I'm studying the Zeta Converter topology for Photovoltaic Applications.
In every documents, it is specified that the switch is PMOS. I don't understand why a PMOS is needed. Which are its advantages?
Being a switch, is it possible to use an NMOS instead of PMOS? Obviously, an isolated driver is needed.
Here some notes from TI about this topology:
https://www.ti.com/lit/an/slyt372/slyt372.pdf?ts=1605336852595
Thank you.
Ian0
Joined Aug 7, 2020
13,310
The driver is tricky for an N-channel device, because the drain of the P-channel (or the source of the N-channel) goes below the negative supply when the device is off. So you are correct about the isolated driver, because the charge-pump drivers don't like the output below their negative supply.
I don't see any other problems.
But if you can choose which is the "common" terminal of your system then there's nothing stopping you implementing the zeta converter for a negative supply (with an N-channel device with the output on the drain). Vin becomes negative, the diodes and electrolytics turn round. Then you can use an ordinary low-side driver. The problem then moves to how to sense the output voltage.
