Shown connection in Post #301ADC VDD ---> 5V
ADC GND ---> GND
ADC SDA ----> PIC SDA
ADC SCL -----> PIC SCL
ADC ADDR----> GND
Yes I've connected ADDR Pin to ground PIN of BoardDo you have the ADDR pin strapped to ground?
ADC GND ---> GND
ADC ADDR----> GND
Sorry. You did indicate that..Yes I've connected ADDR Pin to ground PIN of Board
No, Compiler doesn't gives any warningAny compiler warnings to go along with those red icons?
No, Start condition doesn't generate error. When I send slave address. slave doesn't accept addressDoes sending Start generate an error?
sorry. I did changes in code because I thought logically I'm doing right. I removed few routines because that was not necessary to achieve current goal.BTW: it is not necessary or desirable to rename the I2C routines for the device. The read and write routines are general purpose in nature and should just be named I2C_Read and I2C_Write. Every time you edit working code you run the risk of breaking it - same for anybody. Once any routine is debugged and its operation is understood, leave it alone and let it work for you.
I've doubt I haven't connected channel pins and alert pin yet so could this be a reason for Not acknowledgement address? should I connect alert pin to ground ?EXAMPLE: in line 135, it used to force the RW/ bit low using something like (address & 0xfe). Now you specify the address as a fixed address with the RW/ bit == 0. That should work in WRITE but when you try to READ, you will need just the slave address and let the read routine work the RW/ bit. That was already done, debugged and working and now it's gone.
#define _XTAL_FREQ 20000000 // crystal 20MHz
// PIC18F45K80 Configuration Bit Settings
// CONFIG1L
#pragma config RETEN = ON // VREG Sleep Enable bit (Ultra low-power regulator is Enabled (Controlled by SRETEN bit))
#pragma config INTOSCSEL = LOW // LF-INTOSC Low-power Enable bit (LF-INTOSC in Low-power mode during Sleep)
// SOSCSEL = No Setting
#pragma config XINST = OFF // Extended Instruction Set (Disabled)
// CONFIG1H
#pragma config FOSC = HS2 // HS oscillator (high power, 16 MHz-25 MHz
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = ON // Power Up Timer (Enabled)
#pragma config BOREN = OFF // Brown Out Detect (Disabled in hardware, SBOREN disabled)
#pragma config BORV = 0 // Brown-out Reset Voltage bits (3.0V)
#pragma config BORPWR = LOW // BORMV Power level (BORMV set to low power level)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1 // Watchdog Postscaler (1:1)
// CONFIG3H
#pragma config CANMX = PORTC // ECAN Mux bit (ECAN TX and RX pins are located on RC6 and RC7, respectively)
#pragma config MSSPMSK = MSK5 // MSSP address masking (5 bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = OFF // Stack Overflow Reset (Disabled)
#pragma config BBSIZ = BB1K // Boot Block Size (1K word Boot Block size)
// CONFIG5L
#pragma config CP0 = ON // Code Protect 00800-01FFF (Enabled)
#pragma config CP1 = ON // Code Protect 02000-03FFF (Enabled)
#pragma config CP2 = ON // Code Protect 04000-05FFF (Enabled)
#pragma config CP3 = ON // Code Protect 06000-07FFF (Enabled)
// CONFIG5H
#pragma config CPB = ON // Code Protect Boot (Enabled)
#pragma config CPD = ON // Data EE Read Protect (Enabled)
// CONFIG6L
#pragma config WRT0 = ON // Table Write Protect 00800-01FFF (Enabled)
#pragma config WRT1 = ON // Table Write Protect 02000-03FFF (Enabled)
#pragma config WRT2 = ON // Table Write Protect 04000-05FFF (Enabled)
#pragma config WRT3 = ON // Table Write Protect 06000-07FFF (Enabled)
// CONFIG6H
#pragma config WRTC = ON // Config. Write Protect (Enabled)
#pragma config WRTB = ON // Table Write Protect Boot (Enabled)
#pragma config WRTD = ON // Data EE Write Protect (Enabled)
// CONFIG7L
#pragma config EBTR0 = ON // Table Read Protect 00800-01FFF (Enabled)
#pragma config EBTR1 = ON // Table Read Protect 02000-03FFF (Enabled)
#pragma config EBTR2 = ON // Table Read Protect 04000-05FFF (Enabled)
#pragma config EBTR3 = ON // Table Read Protect 06000-07FFF (Enabled)
// CONFIG7H
#pragma config EBTRB = ON // Table Read Protect Boot (Enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#pragma warning disable 520
#include <xc.h>
#define ADC_ADDRESS_WRITE 0x90 //first 7-bit I2C address with a low R/W bit
#define CONFIG_REGISTER 0x01 // points to Config register
#define MSB_CONFIG_REGISTER 0x84 // MSB of the Config register to be written
#define LSB_CONFIG_REGISTER 0x83 //LSB of the Config register to be written
void Port_Initialized (void)
// LATx registers
LATA = 0x00;
LATB = 0x00;
LATC = 0x00;
LATD = 0x00;
LATE = 0x00;
// TRISx registers
TRISA = 0x00; // All are output, Unused
TRISB = 0x00; // all are output, Unused
TRISC = 0x18; // SDA SCL
TRISD = 0x00; // all are output, Unused
TRISE = 0x00; // All are output, Unused
ANCON0 = 0x00; // Set to digital port
ANCON1 = 0x00; // Set to digital port
CM1CON = 0x00; // Comparator off
CM2CON = 0x00; // Comparator off
ADCON0 = 0x00; // A/D conversion Disabled
ADCON1 = 0x00; // A/D conversion Disabled
ADCON2 = 0x00; // A/D conversion Disabled
//Initialize I2C in master mode
void I2C_Initialized(void)
SSPSTAT=0x80; //Slew rate control is disabled for Standard Speed mode (100 kHz and 1 MHz)
SSPCON1=0x28; // I2C Master mode, clock = FOSC/(4 * (SSPADD + 1))
SSPCON2=0x00;
SSPADD = 49;
// Send an I2C START
// Return 0 if all ok, 1 if bus collision
__bit I2C_Start(void)
BCLIF = 0; //Clear 'Bus collision" flag
SEN = 1; //initiate a START cycle
while (SEN); //wait until it has been sent
return BCLIF; //return value of BCLIF flag
// Send an I2C STOP
void I2C_Stop(void)
PEN = 1; //initiate a STOP cycle
while (PEN); //wait until it has been sent
//Receive one byte. ackflag=0 to send ACK, or 1 to send NAK in reply
//Send one byte. Return 0 if ACK received, or 1 if NAK received
__bit I2C_Sendbyte(unsigned char dat)
SSPBUF = dat;
asm("nop"); //wait a little for R_W to be set
while (R_W); //wait until byte sent and ACK/NAK received
return ACKSTAT;
//Return 0 if all OK, 1 if bus error, 2 if slave address NAK, 3 if slave register NAK, 4 if slave data NAK
unsigned char ADC_Write(unsigned char adc_address, unsigned char config_register, unsigned char MSB_config, unsigned char LSB_config )
if (I2C_Start() ) //send a start, and check if it succeeded
return 1; //abort if bus collision
//send the I2C slave address
if (I2C_Sendbyte(adc_address & 0xfe)) //
I2C_Stop(); //if address was NAKed, terminate the cycle
return 2; //and return error code
//send the Config register
if (I2C_Sendbyte(config_register))
I2C_Stop(); //if register was NAKed, terminate the cycle
return 3; //and return error code
//send MSB of Config register
if (I2C_Sendbyte(MSB_config))
return 4; //and return error code
//send the LSB ofConfig register
if (I2C_Sendbyte(LSB_config))
return 5; //and return error code
I2C_Stop();
return 0; //no error
void main(void)
unsigned char ADC_Send;
Port_Initialized ();
I2C_Initialized();
ADC_Send = ADC_Write(ADC_ADDRESS_WRITE , CONFIG_REGISTER, MSB_CONFIG_REGISTER, LSB_CONFIG_REGISTER );
while(1);
It looks like you're doing things right so far. Try changing the slave address to 0xa0 (ONLY, don't change any other names etc) and see if the EEPROM ACKs that slave address. That will verify the I2C bus.I'm sure there is no problem in code because it's same code I used before for EEPROM and RTC
I have tried many ways to solve the problem by myself. I have already soldered the pins of the LCD directly on the development board. I have soldered the pull UP resistor on small PCB. So I need only few jumper wiresThe wiring of course must be perfect. Jumper leads are useful for initial hookups but I like wire and solder. If you can get some small, solid wire to make permanent hookups, you will eliminate the jumper problem.
As You Know my understanding for reading PCB layout is very poor. I will need help to connect decoupling capacitor on board. Where do I have to connect the decoupling capacitor,The chips need to be decoupled for best operation. At the very least, a .1uF ceramic on all power pins to ground on each chip will eliminate decoupling as a possible problem
The board takes 0 to 12 volts AC/DC. I have an regulated adaptor that converts 230 volts into 12V. So the output of this adaptor goes directly to the input of the development board.Make sure your power supply is solid. Bad power is the root of many problems.
I save the working code and don't do any modification.Load the last code that worked for that device and test it. If it worked once, it has to work again IF the wiring is good AND there are no other problems in the code. It is common for code to appear to work in one test but won't work later if your initialization is incomplete or wrong. I don't know what in particular you are using but if you load it up, test it and post the exact code here, we can help sort it out. Once it is fixed LEAVE IT ALONE and add the next thing. It would be a good thing to put working, tested code for a particular module (like the LCD) in another C source file and include a header file for it in the main code. That way, you can't break it while you are working on another module.
I really disappointed I don't know why even after working hard, I don't get success. It seems that all the hard work that I was doing till late at night has become wasteFrustrating indeed.
It's more important to work smart. Have a plan and stick to the plan until success.I really disappointed I don't know why even after working hard, I don't get success. It seems that all the hard work that I was doing till late at night has become waste
As far as I understand the problem is within hardware, because we have working code that were working before. We just have to find out why it's not working now. For example EEPROM code, post #229, #231It's more important to work smart. Have a plan and stick to the plan until success.
What module do you want to work on?
Post the EXACT code you have that isn't working and we can drill down into that.
Yes, it sounds like you broke something, especially since none of the previous working codes are now working.As far as I understand the problem is within hardware, because we have working code that were working before.
It seems to me that this problem may be happening due to decoupling capacitor. Datasheet recommend few capacitor's but there are no required capacitors on the board.Yes, it sounds like you broke something, especially since none of the previous working codes are now working.
Once you identify your problem, consider making the wiring permanent. I like using 30ga wire-wrap wire. Since you have .025" square pins on the board, consider wire wrapping your connections. Properly done, wire wrap is as good or better than solder and easily changable with the little twist tools.
I don't understand where to add decoupling cap at the bottom of board
I have identified pins for VDD and VSS shown with red and black circle in the layout.Cap across pins 11 and 12 and another cap across pins 32 and 31.
10 uF Capacitor's one end will be connected to pin number 6 and the other end will be connected to ground.You also need a cap between pin 6 VDDCORE and ground as we discussed earlier. See section 2.4 in the datasheet.
?? Pick a known Vss pin and follow the trace.10 uF Capacitor's one end will be connected to pin number 6 and the other end will be connected to ground.
Can you tell which is the nearest ground connection to where negative of cap will connect?
"10uF cap to VDDCORE."
What type of 10uF capacitor should be, ceramic or electrolytic capacitor? I have 10uF electrolytic capacitor
If that's all you have it's better than nothing. The datasheet covers exactly what you need, though.See section 2.4 in the datasheet.
a low-ESR (< 5Ω)
capacitor is required on the VCAP/VDDCORE pin to
stabilize the voltage regulator output voltage. The
VCAP/VDDCORE pin must not be connected to VDD and
must use a capacitor of 10 μF connected to ground. The
type can be ceramic or tantalum. Suitable examples of
capacitors are shown in Table 2-1. Capacitors with
equivalent specifications can be used.
As you use trough hole (leaded) components, then better put tantalum or electrolytic one there. Microchip suggest using low ESR capacitors to core Vdd but i noticed that any capacitor between 10 to 22 uF works."10uF cap to VDDCORE."
