I've solved my problem by changing new cableLOL! If it were not for the 3 way tag team we've created, things might be differentI appreciate the respites, much appreciated.
Case in point @Djsarakar , It would be really nice to know if you got the terminal echo working before going off in some new task with new IO code and a host of new errors. That is ..uhh.. frustrating, for me at least, because I never quite know where things are and I don't like solving the same problem more than once.
I'll leave it here for now, carry on and good luck!
I wrote the LED test program because I was not sure that whatever I typed on terminal I am getting it back. Sometimes I was getting what I was typing and sometime I wasn't getting back what I was typing.
I wrote and posted the LED program in a hurry, then went to the shop to buy new serial cable. Changing the cable solved my problem
I've trouble with development board. Even before this the LCD was not working due to jumper wires. now I have directly mounted the LCD on the board I have solder and de soldered the pull up resistor many times on the board to run RTC.
Here is working program for LED I've written and It works as I wanted. you can test @hexreader on your board
C:
#define _XTAL_FREQ 8000000
// Configuration bits: selected in the GUI
// CONFIG1L
#pragma config RETEN = OFF // VREG Sleep Enable bit->Ultra low-power regulator is Disabled (Controlled by REGSLP bit)
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit->LF-INTOSC in High-power mode during Sleep
#pragma config SOSCSEL = DIG // SOSC Power Selection and mode Configuration bits->Digital (SCLKI) mode
#pragma config XINST = OFF // Extended Instruction Set->Disabled
// CONFIG1H
#pragma config FOSC = INTIO2 // Oscillator->Internal RC oscillator
#pragma config PLLCFG = OFF // PLL x4 Enable bit->Disabled
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor->Disabled
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode->Disabled
// CONFIG2L
#pragma config PWRTEN = OFF // Power Up Timer->Disabled
#pragma config BOREN = SBORDIS // Brown Out Detect->Enabled in hardware, SBOREN disabled
#pragma config BORV = 3 // Brown-out Reset Voltage bits->1.8V
#pragma config BORPWR = ZPBORMV // BORMV Power level->ZPBORMV instead of BORMV is selected
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer->WDT disabled in hardware; SWDTEN bit disabled
#pragma config WDTPS = 1048576 // Watchdog Postscaler->1:1048576
// CONFIG3H
#pragma config CANMX = PORTB // ECAN Mux bit->ECAN TX and RX pins are located on RB2 and RB3, respectively
#pragma config MSSPMSK = MSK7 // MSSP address masking->7 Bit address masking mode
#pragma config MCLRE = ON // Master Clear Enable->MCLR Enabled, RE3 Disabled
// CONFIG4L
#pragma config STVREN = ON // Stack Overflow Reset->Enabled
#pragma config BBSIZ = BB2K // Boot Block Size->2K word Boot Block size
// CONFIG5L
#pragma config CP0 = OFF // Code Protect 00800-01FFF->Disabled
#pragma config CP1 = OFF // Code Protect 02000-03FFF->Disabled
#pragma config CP2 = OFF // Code Protect 04000-05FFF->Disabled
#pragma config CP3 = OFF // Code Protect 06000-07FFF->Disabled
// CONFIG5H
#pragma config CPB = OFF // Code Protect Boot->Disabled
#pragma config CPD = OFF // Data EE Read Protect->Disabled
// CONFIG6L
#pragma config WRT0 = OFF // Table Write Protect 00800-01FFF->Disabled
#pragma config WRT1 = OFF // Table Write Protect 02000-03FFF->Disabled
#pragma config WRT2 = OFF // Table Write Protect 04000-05FFF->Disabled
#pragma config WRT3 = OFF // Table Write Protect 06000-07FFF->Disabled
// CONFIG6H
#pragma config WRTC = OFF // Config. Write Protect->Disabled
#pragma config WRTB = OFF // Table Write Protect Boot->Disabled
#pragma config WRTD = OFF // Data EE Write Protect->Disabled
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protect 00800-01FFF->Disabled
#pragma config EBTR1 = OFF // Table Read Protect 02000-03FFF->Disabled
#pragma config EBTR2 = OFF // Table Read Protect 04000-05FFF->Disabled
#pragma config EBTR3 = OFF // Table Read Protect 06000-07FFF->Disabled
// CONFIG7H
#pragma config EBTRB = OFF // Table Read Protect Boot->Disabled
#include <xc.h>
#include <stdio.h>
#include <conio.h>
#define LED LATDbits.LATD2
void PIN_MANAGER_Initialize(void)
LATx registers
LATE = 0x00;
LATD = 0x00;
LATA = 0x00;
LATB = 0x00;
LATC = 0x00;
TRISx registers
TRISE = 0x07;
TRISA = 0xEF;
TRISB = 0x01;
TRISC = 0xBF;
TRISD = 0x00;
ANSELx registers
ANCON0 = 0x00;
ANCON1 = 0x00;
CM1CON = 0; // Comparator off
CM2CON = 0; // Comparator off
ADCON0 = 0; // A/D conversion Disabled
void OSCILLATOR_Initialize(void)
// SCS FOSC; HFIOFS not stable; IDLEN disabled; IRCF 8MHz_HF;
OSCCON = 0x60;
// SOSCGO disabled; MFIOSEL disabled; SOSCDRV Low Power;
OSCCON2 = 0x00;
// INTSRC INTRC; PLLEN disabled; TUN 0;
OSCTUNE = 0x00;
// ROSEL System Clock(FOSC); ROON disabled; ROSSLP Disabled in Sleep mode; RODIV Fosc;
REFOCON = 0x00;
void EUSART1_Initialize(void)
// Set the EUSART1 module to the options selected in the user interface.
// ABDOVF no_overflow; TXCKP async_noninverted_sync_fallingedge; BRG16 16bit_generator; WUE disabled; ABDEN disabled; RXDTP not_inverted;
BAUDCON1 = 0x08;
// SPEN enabled; RX9 8-bit; RX9D 0; CREN enabled; ADDEN disabled; SREN disabled;
RCSTA1 = 0x90;
// TX9 8-bit; TX9D 0; SENDB sync_break_complete; TXEN enabled; SYNC asynchronous; BRGH hi_speed; CSRC slave_mode;
TXSTA1 = 0x24;
SPBRG1 = 0xCF;
SPBRGH1 = 0x00;
void SYSTEM_Initialize(void)
PIN_MANAGER_Initialize();
OSCILLATOR_Initialize();
EUSART1_Initialize();
//Receive Byte
//char Receive_Byte(void)
char getch()
if(RCSTAbits.OERR == 1)
RCSTAbits.CREN = 0;
NOP();
RCSTAbits.CREN = 1;
while(RCIF == 0 ); // Wait till the rx register becomes empty
return (RCREG);
//Send a byte
void putch(char message)
while(TXIF == 0 ); // Wait till the transmitter register becomes empty
TXREG1 = message;
void String(char *p)
while(*p != '\0') {
__delay_ms(1);
putch(*p);
p++;
void main(void)
char Receive ;
char message[]= {"Hello"};
SYSTEM_Initialize();
__delay_ms(10); // Wait for 10 ms
String(message); // Send one byte to hyper terminal
while (1)
Receive = getch(); // Receive a byte from hyper terminal
if (Receive == '1')
LED = 1;
__delay_ms(1000);
LED = 0;
__delay_ms(1000);
else
LED = 0;
return;
