IMU evaluation/development board
d4d0m3n
Joined Sep 24, 2023
30
I would like to buy a board with ICM-46288, which I could start connecting and programming on ESP32.
I found this one ( EV_ICM-42688-P ) on Farnell, but I'm not sure it's meant to be used on a typical protoboard:
Is it? Or is it meant to be connected to some special connector or even gadget?
What worries me are not the positioning and size, but the functionality - if it has the same pinouts as the following one? That's all I need. The following is custom made.
d4d0m3n
Joined Sep 24, 2023
30
@Ya’akov
Magnetometers are not integrated into modern IMUs.
May I ask for another advice - what type of magnetometer would you use with it? I need it only for the re-orientation, due to errors of ICM.
Ya’akov
Joined Jan 27, 2019
10,296
@Ya’akov
I don’t have a particular answer. I would search for the best ESP32 and development platform compatible library for a magnetometer and choose based on that.
