Hello, everyone!
I have a problem with approaching a university project, which aim is to detect the phase drifts (difference, deviation) between a mains supply voltage and either an internal reference and externally input reference signal. The system should be micro-controller based (MSP430).
So I have 4 questions:
1) Any suggestions on how to approach the project and what equipment will be needed?
2) Could XOR gate be used for the two signals to be combined and receive an output signal, which width will be equal to the phase difference?
3) Convert the signal using a Schmitt trigger?
4) The phase drifts within the 50Hz frequency range will be too small to detect, so a calibration and verification feature is needed. Any thoughts on that?
I would appreciate any help! Thank you!
