Then that's what you need.Sticker on the board says F10A.
As a complete novice in this realm, I'm willing to consider your expertise.However, if you would like to go down the path of matching them, I could share a simple schematic which I have used in the past.
I assume it's sufficient to match them in sets of three, yes?Without a full fledged curve tracer, what you could realistically achieve with a static Hfe measurement would be to closely match (or as close as possible) the gains, which would result in the collector currents to be as similar as possible.
Why is this important? For self heating reasons: the transistor drawing the larger current will heat more. With the additional aggravation that the more that a bipolar transistor heats up, the current draw increases. This could lead to, depending on the initial imbalance, to an eventual thermal runaway.
Will this happen to you?
I. Don’t. Know.
They won't be matched by either Motorola or Peavey, they will be selected for gain.I assume it's sufficient to match them in sets of three, yes?
Que?There may be a driver of the same package with different part number.
Make sure all has the same pair numbers
This look like peavey series power amp PCB.. I see these in there music power amps around 2kW ones or so. Same brand.. No wonder they use the same topology. These are very good ampsI got the whole thing apart now. Here's a photo of the top side of the board:
I circled the telepathic thermal link diodes. The bodies of the diodes are installed vertically into the bulk of the heat sink. There is no thermal compound, best I can tell.
Mica insulators (and insulating shoulder washers inserted from the other side of the heatsink):
I'm going to buy 10 ea. of MJ15024G and MJ15025G from Mouser, about $120 USD with shipping. I'll measure what I can, and choose the best 12 out of 20.
Do I re-use the old mica insulators, or buy new ones? Can I replace them with TO-3 Sil-Pads and eliminate the compound mess? Or, is this a case where it's best to keep it numbers-matching factory original?
The fuses (4) are 314 series. I found exact replacements.
I edited ( added ) the post after seeing the picture. All power drivers are same pairs.Que?
No shorts C to E, and good Vbe on all 4. Two thermal switches mounted on the TO-3s read closed. One on opposite side of board mounted to middle of heat sink reads closed.I believe those TO220'S are the drivers.
Do check them for shorts or leaks.
Also check the thermal switches too.
That's why they didn't save your expensive power transistors.
Peavey Advice | General Electronics Chat | 32 | |
| B | Peavey Bandit 112 amplifier, NFB with two center tapped secondaries. | Analog & Mixed-Signal Design | 20 |
