Peavey XRD 680S Plus
joeyd999
Joined Jun 6, 2011
6,456
That's why they didn't save your expensive power transistors.
They have to be rated so that they don't blow on the inrush when the capacitors charge, so they are too large,
They would have done a little better using a lower value of Time-delay fuse, or much better if they were after the capacitors.
The counter-argument is that they wouldn't fail in the event of a rectifier or capacitor short, but almost certainly the transformer primary fuse would.
I see this as odd myself. But I'm not an audio engineer, and this was a highly rated mixer/amp back in the day.
joeyd999
Joined Jun 6, 2011
6,456
Yes it is. And still intact after all these years!
It reads 1.1 ohms cold. Sound about right?
Two thermal switches mounted on the TO-3s read closed. One on opposite side of board mounted to middle of heat sink reads closed.
Correction: the central thermal switch is open. It connects to the power entry board, and I believe it is a crowbar that blows the mains fuse upon closure.
Ian0
Joined Aug 7, 2020
13,267
That would seem odd, if not a bit dangerous (especially for those people who use tinfoil fuses)
R!f@@
Joined Apr 2, 2009
10,007
Are you saying you just replace the blown ones? Even though the original good ones are nearly 30 years old and a completely different part than what's available today?
No no..
I am saying to test the amp I use just one pair and power up.
to do tests. After I am satisfied I install all pairs
joeyd999
Joined Jun 6, 2011
6,456
Yup...Crowbar protection triac.
I have seen these creating issues.
Do you have the schema...
I believe these are wired across the output or something. It was log time ago when I fixed peavey's
If I had the schematic, this would be much easier. There is this, though, which has many similarities:
https://forum.allaboutcircuits.com/threads/peavey-xrd-680s-plus.205749/post-1971924
No no..
Yes! Makes much more sense. Thanks.
