Peavey XRD 680S Plus
joeyd999
Joined Jun 6, 2011
6,561
Do you have the transistor’s part number? A photo of the device will be nice.
I don’t want to discourage you, but TO-3 packaged transistors will give you a sticker shock.
Money is no object.
I am unsure of the part numbers as of yet. Hopefully, they will reveal themselves as i continue the disassembly.
I suspect the OEM parts will be long discontinued. I hope the audio experts here will help me zero in on suitable replacements.
Ian0
Joined Aug 7, 2020
13,317
2N3055 (NPN) and MJ2955 (PNP) is a common complementary pair.
300W into 4Ω would require ±50V supplies assuming no loss, no output resistors and no ripple so a 60V transistor isn’t going to work.
Vceo rating have to be quite high to avoid the secondary breakdown part of the safe operating area curve.
joeyd999
Joined Jun 6, 2011
6,561
Joey not sure what part he has.
C'mon !! Take the freakin' thing apart. Show me some guts
The last time I handled a discrete transistor linear amplifier was in an EEN204 lab at university over 100 years ago.
The last time I dealt with a 600W discrete transistor power amp was......never.
I like this amp...it's got history (it's the one and only thing I ever stole from a church). I'd like it to work again, someday.
That, and I don't have a lot of time to spend on it.
I am good at what I'm good at, and this ain't one of them.
This is why I'm here. Thanks, for your continued help, Ian.
BTW, I suspect -- from posts I've read on the internet -- these parts will be suitable:
https://www.onsemi.com/download/data-sheet/pdf/mj15022-d.pdf
https://www.onsemi.com/download/data-sheet/pdf/mj15023-d.pdf
Comments?
Ian0
Joined Aug 7, 2020
13,317
Comments?
I was going to send you to On-Semi’s website.
MJ15022/23 would work well. Note that the secondary breakdown doesn’t start until there is 60V across the device, so isn’t a problem.
MJ15003/4 are Also common for this type of amplifier.
schmitt trigger
Joined Jul 12, 2010
2,295
House numbers, meaning that they are a commercial parts which have been screened for a particular parameter, most likely Hfe.
I am sure that I already know this answer, but I will ask the question; can you test for Hfe?
EDIT;
The same PDF file has the note that house numbers are selected for gain
joeyd999
Joined Jun 6, 2011
6,561
EDIT;
That was going to be my next question: do I just buy 6 of each PNP and NPN, or do I need to buy extras and match for some parameter(s) like hfe and Vbe?
Or do I need to select for a minimum hfe? And, under what operating conditions?
Damn...analog is pretty annoying compared to digital.
Ian0
Joined Aug 7, 2020
13,317
Just buy 6 off each. If they are from a reputable supplier, you will get 6 out of the same batch.
The design has emitter resistors which will keep the current evenly shared.
joeyd999
Joined Jun 6, 2011
6,561
Are they labelled F10A or T10A?
If they are before the main power supply capacitors then they will almost certainly be Time delay. If they are just in the output stage they should be Fast.
Sticker on the board says F10A.
