Hello everyone,
I am trying to make an amplifier board based on the TI IC TPA3123D2. It has several power pins and ground pins. Here is a relevant excerpt from the datasheet:
Many thanks,
Tim
- Grounding—The AVCC (pins 19 and 20) decoupling capacitor and VBYP (pin 7) capacitor should each be grounded to analog ground (AGND, pins 8 and 9). The PVCCx decoupling capacitors and VCLAMP capacitors should each be grounded to power ground (PGND, pins 13, 14, 23, and 24). Analog ground and power ground should be connected at the thermal pad, which should be used as a central ground connection or star ground for the TPA3123D2
Many thanks,
Tim
