Hello, i have come up with the schematic below and would like to turn it into a workable PCB. I am unsure of connectors but pretty sure the main supply one needs an update just cant find how/where to get it. The schematic calls for a single 12v and ground as the main power supply and then has 8 outputs that are switched with mosfets. the total system i want to be capable of 100A at 12V. the 8 pin header will be controlled from a microcontroller with 5V.
feel free to add any input on the design or any recommendations you might have its my time doing any of this.
8-pin Connector: A2005WR-8P
2 pin screw terminal (supply): DB128V-5.0-2P-BK
i can attach any files needed if that helps just let me know
