PCB cost w/ shipping???
johnaustinkaty
Joined Jul 16, 2021
284
I have been getting my PCB s from JLCPCB (China). The shipping is running approx three times the cost of the boards. Are you experiencing something similar? I usually select DSL for shipping.
Thx for any feedback and suggestions....
dendad
Joined Feb 20, 2016
4,641
I use the lowest price shipping and just wait longer.
JLCPCB is so much better that what we had to use years ago. There was an extra $200 setup fee on top of the board and shipping charges.
I am very pleased with JLCCPCB and have used them for some years.
One thing I have not tried is to make use of their assemble service.
Some friends of mine do that and the results and prices are very good.
Dave Lowther
Joined Sep 8, 2016
349
I used JLCPCB for the first time a couple of weeks ago because PCBWay were having payment system issues. As a new customer, and using the cheapest shipping method, this is how much it cost me for 5 double sided PCBs about 4 inches x 3 inches in size.
Ordered 15th Jan, arrived in UK 26th Jan. Quality seems very good. Built one with no problems.
Ya’akov
Joined Jan 27, 2019
10,330
I think there is a baked in assumption that somehow the shipping should cost less than what you are buying. That's unwarranted, it depends on several factors. Fast shipping from China will be by air while slower options can use the much less expensive container ships.
Simple observation of weight of a parcel is not a reliable way to decide how much you should reasonably pay. If you need to save money, pay with the waiting time instead. On the other hand, make sure you properly account for the cost of the wait—if there is one for you.
engr_david_ee
Joined Mar 10, 2023
364
PCBway or JLCPCB which one you recommend ? considering shipment to Europe. Practically how many days should it take to get PCB in North European country.
Can we check the price of manufacturing by uploading the Gerber files to their websites before we place an order ?
johnaustinkaty
Joined Jul 16, 2021
284
Yes. They will provide a quote before you move forward.
johnaustinkaty
Joined Jul 16, 2021
284
I really like the service and quality I get from JLCPCB. I don't plan on changing. Maybe I have been selecting the wrong shipping method...
I think I may have been selecting the expedited DHL service.
panic mode
Joined Oct 10, 2011
5,317
colleague says he was also choosing postal service which was much cheaper and would take about as long or at most 2-3 days longer. i always use couriers - DHL, FedEx, UPS and these options cost about the same.
johnaustinkaty
Joined Jul 16, 2021
284
There are two DHL options. One is just DHL and the other is DHL with a an acronym after it. Maybe "DPP"? I have chosen that one. Maybe that is the issue. I'll have to investigate.
engr_david_ee
Joined Mar 10, 2023
364
We have once paid some time ago 600 USD for 5 pcs PCB. The PCB size was 160 mm x 100 mm. Eight layers. All the internal layers were planes. The routing was only on top and bottom. I guess we have paid much. Never tried JLCPCB or PCBWay before.
dendad
Joined Feb 20, 2016
4,641
I have had 4 layer PCBs from JLCPCB and been very happy with them. The price was WAY less than I used to get here in Australia. My friends have dome more layers.
Just out of interest, send you 8 layer PCB to them for a quote.
It will be quite interesting to see the result.
panic mode
Joined Oct 10, 2011
5,317
decades ago, 20pcs of 8"x6" two layer 2oz copper boards, made in Canada in about two weeks and costed me about $1k.
on top of that i still had to buy all parts, and then solder them all (a mix of THT and SMD). parts alone costed more than boards and it would take days to populate all boards.
today i get same size boards in about a week from China, that is half the time. PCB cost together with expedited shipping is still only about 10% of what i used to pay. but... nowadays i rarely order just blank PCBs. most of my orders include PCBA. this gives me turnaround of about two weeks but - advantages are that all parts are purchased for fraction of what they cost me here, and the boards are not only fully populated (time saver..!). but also clean (in absolutely pristine condition). so now, even with cost of parts, setup costs, PCB assembly and expedited shipping this still comes to about 30-35% of what once used to cost me to get just the bare bone PCBs.
in light of that, i really cannot complain about shipping costs. ;)
the best of all is the quoting system. i really like possibility to instantly see in 3D boards fully populated - before placing order. no waiting a day or two for an email. on average in 15min after submission, design is checked, approved and in production.
panic mode
Joined Oct 10, 2011
5,317
btw i was using economy and standard assembly and designs created for economic assembly (parts only on one side of the board, higher temperature for faster soldering) ended up costing about the same with standard assembly. one of used parts was tiny relay signal which would get slightly deformed during soldering. not one relay failed but... if one knows how to look, it could be observed that originally flat surfaces are not perfectly flat. i had no time to redesign for alternative part (which was a bit larger) so i simply accepted it as is. run bunch of tests and was happy to see that they are all ok. on repeat orders i simply accepted to use standard assembly (parts can be on both sides of the board, soldering temperature is lower).
i try to use basic parts as much as possible. this speeds up assembly since no reloading of the machine is needed and $3 per part type goes away. i also prefer to use same parts if possible, even on passives. result is that some resistors or capacitors are actually 2 or even 3 parts.
if ordering bunch of small boards, quoted price is quite a bit cheaper if you do panelizing yourself. but JLC does not like it when multiple designs are on same panel, so expect follow up call and paying small surcharge. some of the boards were too small too handle and had to be panelized in order to use PCBA.
i use KiCad and there are no out of box mouse bites in the library. i remember doing it first time and finding some online. it looked good but it did not go well - while the idea was fine, result was something that was very hard to use (to panelize). and finished boards were waaay too hard to separate. this was causing stress on the PCB and components. one of the boards did not work and it turned out that one of 0603 resistor near mouse bite was broken in half. that was easily found and repaired but made me create own versions of mouse bites which work way better.
