Output voltage minimal changing -Byte force sensor
rockyallabtckts
Joined Jan 25, 2025
15
Hello everyone,
I'm working on an electronics project that uses a flexi force sensor A201 , INA333 instrumentation amplifier and esp32 module ,and I've simulated the circuit using lt1167(in place of ina333), changing the resistance value(in place of sensor) and used behavioural voltage source (in place of adc value conversion on esp32) in LT spice.
However, I'm running into an issue:
when I apply force to the sensor, I observe minimal step variation in mV range in the LT1167's output voltage and no or minimal step variation on bv source values
What I Have Tried So Far :
1.Tried to invoke the ina333 spice models but simulation was not behaving properly.
2. hence used lt1167 built in library ina which is present on ltspice platform.
3. I updated circuit to resolve the issue by adding capacitors to ensure the noise is the problem.
4. Later I checked for the different voltage levels but no change.
5. Later I thought voltage divider may be problem and hence removed it but no effects.
6. also changed r2 value and gain r3 value but it just increased the output voltage swing and bv source value.
7.Also employed the opamp to provide the stable buffer to ref pin.
Are there any circuit modifications or additional components that could help enhance the sensitivity of the circuit?
Any suggestions would be greatly appreciated !
ericgibbs
Joined Jan 29, 2010
21,597
hi rocky,
It appears that the INA model is expecting a dual +/-V supply??
E
I will look for the INA333 model and give that a try.
rockyallabtckts
Joined Jan 25, 2025
15
Hey eric,
since I need to produce byte force measurement system I need to provide input dc of 3.3 V and that 1 Meg resistance is sensor resistance at 0N force I need to have a device such that it should provide me a necessary output voltage swing and the variation in adc values of esp32 .(which in my case used behavioural voltage source)
rockyallabtckts
Joined Jan 25, 2025
15
Hey eric,
sir please reply since I am trying to solve from past 3 days
ericgibbs
Joined Jan 29, 2010
21,597
hi rocky,
I would say for that application a INA amplifier is not suitable, when using a single supply voltage, have you considered a regular high spec OPA.
BTW: some versions of the ESP32 have a very poor linearity span on their ADC conversions.
E
rockyallabtckts
Joined Jan 25, 2025
15
hi rocky,
E
Will check about it and thank you so much for suggestion and if any components required can U mention here sir
rockyallabtckts
Joined Jan 25, 2025
15
I setup by AD8605 opa now ,just the final output voltage swing is increased , still variation in mV range wrt changing resistance which is impossible for adc of esp32 to detect Please reply as soon as possible since I am stuck in this subject sir
ericgibbs
Joined Jan 29, 2010
21,597
hi rocky,
The first step was to check their recommended circuit.
I have simulation three plots using 3 different Rinp resistor values, over the range specified in the A201 datasheet.
Can you confirm that the A201 sensor has a linear or logarithmic scaling??
E
rockyallabtckts
Joined Jan 25, 2025
15
hi rocky,
Found more info on the sensor, the resistance value is logarithmic.
E
http://www.nexgenergo.com/ergonomics/tekscana201.html
hey eric sir ,Thank you so much for the information of A201 sensor and also I didn't aware of the website u shared it's very useful website
Will look forward for the further information of the existing project and will try to design lot more circuits on future
Once again thank you if found any detailed circuit connections of this project Please send so that I can accelerate the process
rockyallabtckts
Joined Jan 25, 2025
15
