Alternator output voltage calculation
wayneh
Joined Sep 9, 2010
18,182
Technically that's a motor, not an alternator. It will probably work as an alternator but the manufacturer doesn't give enough information, at least as far as I can tell, to answer your questions. Calculating an estimated alternator output is not simple and a little data would go a long way. Maybe the manufacturer has some data on this application.
I'm concerned that you're planning to run it at nearly double the rated rpm.
