oscillator
beenthere
Joined Apr 20, 2004
15,819
BillB3857
Joined Feb 28, 2009
2,573
In the case of many oscillators, simple random noise gets amplified repeatedly and fed back to the input until the frequency determining system takes over and allows only amplification of the desired frequency.
Adjuster
Joined Dec 26, 2010
2,148
Essentially, oscillators depend on some kind of amplifying system provided with positive feedback, but this more obvious with some types than others.
At one extreme we have simple oscillators using a single amplifying device with a frequency-selective positive feedback path. In this case it is easy to visualise random noise leading to an increasing signal building up around the feedback loop, assuming that (at least initially) the loop gain is more than one at some frequency where the signal comes back around the loop in phase with itself.
RC oscillators like the 555 are usually analysed in terms of large-signal processes where capacitors charge until a threshold is reached, triggering some event that leads to the capacitor discharging again. That said, the comparators or other trigger devices underlying this process can be considered to be rather specialised amplifiers.
Other oscillators are based on devices which present a negative incremental resistance or trigger characteristic between two terminals. These include tunnel diodes, some gas discharge tubes (including thyratrons) and uni-junction transistors. Here the amplification is an implicit process, a consequence of the negative incremental resistance.
