Oscillator triangle generator
dl324
Joined Mar 30, 2015
18,491
Welcome to AAC!
If this is project for which you will receive a grade, you must show your work. Members won't be giving you answers; we can only try to guide you to a solution.
38,927
Why did you select a circuit with op amps, when you stated you needed to build the op amp from components? :confused:
Building an op amp from components is not a trivial task.
gxg513
Joined Oct 8, 2017
19
It makes no sense to waste you time on a circuit that you won't build.
man,is my first time when i do this.i have 3 more weeks to do it.So instead of the second op amp i tried to build one from components,i will do the same with the first one.But when i try to simulate i have an issue,the outpus signal is still rectangular instead of triangle
Alec_t
Joined Sep 17, 2013
15,162
As you are supposed to be simulating the circuit with LTspice, you can post your .asc, .sub and .asy files here. No need for .rar (which many people won't open).
bertus
Joined Apr 5, 2008
23,026
As said, you can just post the pictures right to the forum.
For now I unpacked the rar file and will post the pictures:
Bertus
gxg513
Joined Oct 8, 2017
19
look,the scheme does not work,is not important whitch program i use.I just need some advices.The scheme is correct but when i build the operational amplifier and put it in the circuits,the output signal is not triangle anymore
