Oscillator Simulation Help
Jony130
Joined Feb 17, 2009
5,599
Use Initial conditions marker.
Or use additional current source ISRC
Tran = PWL(0US 0MA 1US 0.1MA 4US 0.1MA 5US 0MA 10MS 0MA)
Jony130
Joined Feb 17, 2009
5,599
Well your circuit don't have any Automatic gain control.
And this s why opamp is in saturation.
So you need AGC circuit. (Look at my diagram)
And cur set R=51K and C=100pF so the output Frequency we be equal to
Fo = 0.16/RC = 31.4KHz
So need to change Run to time from 1s to 200us
Audioguru
Joined Dec 20, 2007
11,248
A lousy old 741 opamp is 43 years old. Its gain at 31.5kHz is only about 20 and its max output level is only about plus and minus 5V.
The resistors in your circuit are both the same value but its capacitors are not so it doesn't oscillate.
